1 Reply Latest reply on Feb 25, 2014 4:58 PM by Artem Taturevych
    Automation Error
    Evan Heyes
      I am currently getting an automation error when trying to run the following code.
      My intention is to eventually open each part/assembly and automatically take in data from excel and add it into the configuration properties. Currently I have a component array which seems to be filled, but whenever I try and call a method with a defined index it throws an automation error of the form.
      Run-Time error '(9 Digit Number)(f(7 Digit Number)'
      Automation Error
      I think this is a variable type issue but I have not been able to track down the problem, any help would be appreciated.
      Dim FirstDoc As SldWorks.ModelDoc2
      Dim FirstAssembly As SldWorks.AssemblyDoc
      Dim SecDoc As SldWorks.ModelDoc2
      Dim Test As String
      Dim Parts() As SldWorks.Component2
      Dim CompCnt As Integer
      Set FirstDoc = swApp.ActiveDoc
      Set FirstAssembly = FirstDoc
      Parts = FirstAssembly.GetComponents(False)
      CompCnt = UBound(Parts)Debug.Print CompCnt
          Set SecDoc = Parts(1).GetModelDoc2: Debug.Assert Not Parts(1) Is Nothing
        • Re: Automation Error
          Artem Taturevych
          Change the red line.
          Dim Test As String
          Dim Parts As Variant
          Debug.Print CompCnt
          Set SecDoc = Parts(1).GetModelDoc2 : Debug.Assert Not Parts(1) Is Nothing
