Hey folks,
I'm trying to model a control valve that has one input flange and two output flanges. It's causing me tons of issues.
For some reason, it will not create the other routing pipe in the right locations. See attached pictures
I've tried every combination of rpoints and cpoints I can think of. Getting one feature to work, typically ends up in another feature being borken. (EG. If you add rpoints to each flange, then all route line are in the correct spot but the tab and shit+arrow features on drag'n'drop don't work and the route point is misaligned.)
I don't really see why this fails. I have several similar parts that work without issue.
Any suggestions on how I can go about creating this custom routing part?
Craig,
Try this:
- no RPoints (rpoints are points were the route sketch has to go through, seeing as that the route has no continuation in the same co-liniar line there is no need for a Rpoint and in fact would be detrimental. Consider Exc. Red. parts where the same applies)
- on each exit have a Cpoint, 3 exits = 3 cpoints
- Vertical axis called "Vertical" has to be the last feature in the part to work as was intended by SW
Let me know if any of this makes sense to you and if you got it to work.
Have a nice one
Peter
