Is it possible to Run motion as well as stress simulation on Rubber airbags for Air suspension ?
Do you mean solidworks premium or is there a simulation premium too? All i am looking for is to do a study on my air suspension system with four aibags. I will be putting air with certain pressure inside each of them and would like to see the result. (air bag's elongation and stuffs like that.) Do you think that would be possible with solidworks?
what do you want to learn from your analysis? originally you talked about a deformable kinematics problem, now you're talking about what sounds like a static problem.
as for simulation premium, solidworks prem includes static and motion, simulation premium has all analysis types up to dynamic and nonlinear.
it is currently not possible to directly couple those 2 analyses, you would run a motion analysis and pull some info out to stress to run an analysis on your airbag. but depending on your analysis need, you may get everything out of motion.
or you could look at a nonlinear dynamic in simulatino premium
