I need some advice on shaping a piece of corrugated sheet metal. I followed some advice on this forum and tried unfolding sheet metal then sketching the area I wanted to cut out. The problem is the fold lines are not removed and when the flat pattern is suppressed the cut-out is also suppressed. Any advice is appreciated. Thanks.
Manuel Make your cut before flat pattern, using the unfold and fold commands, if
you don't want the bend line to show after that right click on the lines and click hide.
Sent some jpegs to view hope this helps..
