I need to export multy-body part as neutral format(preferably step format) where some bodys are shown and some are hidden. But, for bodys that are hidden in SW file to remain hidden in neutral format after export.
Is it possible to do this in SolidWorks?
Regards,
Ivan
Ivan,
In theory, you can just select the bodies that you want to export, then click on the option to export only the selected bodies.
Because I had some problems using that method many years ago, I got into the habit of deleting the bodies that I didn't want to export. It's easy to delete the Delete Bodies feature when you are done with the exporting.
Jerry S.
