2 Replies Latest reply on Feb 25, 2014 6:36 AM by Artem Taturevych
    Save As PDF with Correct Filename
    Fraser Reekie
      I am modifying an existing macro to save a drawing as a pdf document in specific file location with the revision in the filename. The macro now does both of these things however the filename is not correct. The pdf should be named with the same name as the drawing, instead it is saved with the same name as the drawing plus the sheet name, e.g. SG828456DML - Sheet1_A00 instead of SG828456DML_A00 (SG828456DML is the name of the drawing and _A00 is the revision).
      Public Sub main()
              Dim swDoc As ModelDoc2 = Nothing
              Dim longstatus As Integer = 0
              swDoc = CType(swApp.ActiveDoc, ModelDoc2)
              Dim FilePath As String = ""
              Dim FileRevision As String = ""
              Dim NewFilePath1 As String = ""
              Dim NewFilePath2 As String = ""
              FilePath = swDoc.GetTitle
              FileRevision = swDoc.GetCustomInfoValue("", "Révision")
              NewFilePath2 = (FilePath & "_" & FileRevision)
              NewFilePath1 = Path.ChangeExtension("S:\Wide\Gattlen\FRE\In approval process\" & NewFilePath2, ".PDF")
              longstatus = swDoc.SaveAs3(NewFilePath1, 0, 0)
              MsgBox("Saved " & NewFilePath1, MsgBoxStyle.Information)
      Cheers,
      Fraser
        • Re: Save As PDF with Correct Filename
          Deepak Gupta
          Try these codes
          Dim sFileName As String
          Const FilePath As String = "S:\Wide\Gattlen\FRE\In approval process\"
          Set swModel = swApp.ActiveDoc
          FileRevision = swModel.GetCustomInfoValue("", "Révision")
          sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
          sFileName = Left(sFileName, InStrRev(sFileName, ".") - 1)
          sFileName = FilePath & sFileName & "_" & FileRevision & ".PDF"
          swModel.SaveAs3 sFileName, 0, 0
          MsgBox "Saved " sFileName, vbOKOnly
            Artem Taturevych
            You are using VB.NET so you can just call
            FilePath = Path.GetFileNameWithoutExtension(swDoc.GetPathName())
            instead of
