Hi there,
I don't know if I'm handling my problem the best way and need your advice about it.
1) I'm trying to design a carter with multiple features in a single part.
2) In an attempt to mill the mold I have split the carter in n parts (all separated by 16mm spaced planes as on attached Capture).
3) The resulting parts could be saved in multiple files.
My problem is that I can't see them differently than solid bodies (as seen on Capture2). I can't reach the features derived from these forms, hence I can't use a cam tool like Delcam because no features are reachable at the split-part level.
I know, one workaround would be to create the initial using multiple 16mm layers, but what if I have a solid based on splines that I would like to mill by layers?
Any thoughts?
Thank you very much for your advice...
Patrice,
I am not very clear about the end product you are trying to achive, but if you are trying to get multiple configurations, use a design table and export each configuration into indivital parts
Is this helps you?
