8 Replies Latest reply on Nov 20, 2014 4:15 AM by Nick Hayman
    Quantity in Part from Assembly: Excluded from BOM
    Jared Huffman
      I am using the macro from https://forum.solidworks.com/thread/39750 to count quantities in an assembly and write them to a custom property in each part.  This code skips any lightweight or suppressed components.
      Is there any way to determine if a component is set to "Excluded from BOM" and skip it during the count?
      Thanks for any help!
        • Re: Quantity in Part from Assembly: Excluded from BOM
          Matt Martens
          The IComponent2 object has a boolean property called ExcludeFromBOM that indicates this setting.
              Jared Huffman
              Thanks for the good news!  I apologize for my inexperience, but I'm still having trouble implementing it.  I've tried to add this with no success.  Why doesn't the macro skip Excluded from BOM?
              Here's the section where the instances are counted:
              myCmps = myAsy.GetComponents(False)
              For i = 0 To UBound(myCmps)
              Set myCmp = myCmps(i)
              If (myCmp.GetSuppression = 3) Or (myCmp.GetSuppression = 2) Then
              cCnt = 0
              Set CmpDoc = myCmp.GetModelDoc
              Cfg = myCmp.ReferencedConfiguration
              For j = 0 To UBound(myCmps)
              Set tCmp = myCmps(j)
              If (tCmp.ExcludeFromBOM <> True) Then
              If tCmp.GetSuppression <> 0 Then
              If tCmp.GetModelDoc2 Is CmpDoc Then
              If tCmp.ReferencedConfiguration = Cfg Then
              cCnt = cCnt + 1
              Next j
                  Santosh Pawar
                  Jared,
                  In the macro instead of
                  use
                  Boolstatus =  tCmp.ExcludeFromBOM
                  If Not boolstatus Then
                      Jared Huffman
                      I updated that and it still counts my excluded instances.  Here's the whole macro:
                      ''Originally an equation built by Josh Brady of the Solidworks Forums
                      ''WILL AUTO SUM THE QUANTITY OF UNIQUE PARTS IN ALL ASSEMBLIES WHEN RAN FROM THE TOP ASSEMBLY.
                      ''CURRENTLY NEED TO MANUALLY ADD CUSTOM PROPERY 'Cfg4Qty'-'Text'-'Default' TO TOP LEVEL ASSEMBLY BEFORE RUNNING
                      '' Added several custom properties to each subcomponent -Jared Huffman
                      Sub UpdateQtys()
                      Dim swApp As SldWorks.SldWorks 'added this line
                      Dim Assembly As ModelDoc2 'added this line
                      Dim myAsy As AssemblyDoc
                      Dim myCmps
                      Dim Cfg As String
                      Dim CmpDoc As ModelDoc2
                      Dim i As Long
                      Dim j As Long
                      Dim cCnt As Long
                      Dim NoUp As Long
                      Dim myCmp As Component2
                      Dim tCmp As Component2
                      Dim ProjTitle As String 'The variable for storing the assembly Project Title
                      Dim StatTitle As String 'The variable for storing the assembly Station Title
                      Dim Description As String ' The variable for setting the description custom property
                      Dim StockDescription As String ' The variable for reading the stock description custom property
                      Dim Weldment As String ' The variable for setting the weldment custom property
                      Dim DescriptionOverride As String ' The variable for reading the description override custom property
                      Dim Boolstatus As Boolean
                      Dim tm As Double
                      tm = Timer
                      Set swApp = Application.SldWorks 'added this line
                      Set Assembly = swApp.ActiveDoc 'added this line
                      Set myAsy = Assembly
                      If Assembly.ConfigurationManager.ActiveConfiguration.name <> Assembly.CustomInfo2("", "Cfg4Qty") Then
                      Assembly.Extension.ShowSmartMessage "Qtys not updated due to config", 1000, True, True
                      Exit Sub
                      ProjTitle = myAsy.CustomInfo2(Cfg, "ProjectTitle") 'Read the project title from the assembly
                      StatTitle = myAsy.CustomInfo2(Cfg, "StationTitle") 'Read the station title from the assembly
                      NoUp = 0
                      cCnt = 0
                      If Not Boolstatus Then
                      cCnt = cCnt + 1
                      Next j
                      CmpDoc.AddCustomInfo3 Cfg, "AutoQty", 30, ""
                      CmpDoc.AddCustomInfo3 Cfg, "QtyIn", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "AutoQty") = cCnt
                      CmpDoc.CustomInfo2(Cfg, "QtyIn") = Assembly.GetTitle & " Cfg " & Assembly.ConfigurationManager.ActiveConfiguration.name
                      ''Define Stock Description for machined parts
                      StockDescription = "$PRP:" & Chr(34) & "HasDiameter" & Chr(34) & "$PRP:" & Chr(34) & "StockThickness" & Chr(34) & "$PRP:" & Chr(34) & "HasWidth" & Chr(34) & "$PRP:" & Chr(34) & "StockWidth" & Chr(34) & "$PRP:" & Chr(34) & "HasWall" & Chr(34) & "$PRP:" & Chr(34) & "StockWall" & Chr(34) & " x $PRP:" & Chr(34) & "StockLength" & Chr(34) & " LG"
                      ''Figure out which type of description to show
                      Weldment = CmpDoc.CustomInfo2(Cfg, "Weldment")
                      DescriptionOverride = CmpDoc.CustomInfo2(Cfg, "DescriptionOverride")
                      If DescriptionOverride <> "" Then
                      Description = DescriptionOverride
                      Else
                      If Weldment <> "" Then
                      Description = Weldment
                      Else
                      Description = StockDescription
                      ''Add Description custom property and assign it
                      CmpDoc.AddCustomInfo3 Cfg, "Description", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "Description") = Description
                      ''Added Project Title Custom Property as read from assembly
                      CmpDoc.AddCustomInfo3 Cfg, "ProjectTitle", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "ProjectTitle") = ProjTitle
                      ''Added Station Title Custom Property as read from assembly
                      CmpDoc.AddCustomInfo3 Cfg, "StationTitle", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "StationTitle") = StatTitle
                      ''Add Part Number property from filename
                      CmpDoc.AddCustomInfo3 Cfg, "PartNo", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "PartNo") = Right(CmpDoc.GetTitle, 4)
                      ''Add Weldment Part Number property from filename
                      CmpDoc.AddCustomInfo3 Cfg, "WeldmentNo", 30, ""
                      CmpDoc.CustomInfo2(Cfg, "WeldmentNo") = Right(CmpDoc.GetTitle, 1)
                      Else
                      NoUp = NoUp + 1
                      Next i
                      Assembly.Extension.ShowSmartMessage NoUp & " Parts not updated due to lightweight (" & Timer - tm & "s)", 10000, True, True
                          Santosh Pawar
                          try this
                          If Boolstatus Then
                          GoTo nextiteration
                          Else
                          cCnt = cCnt + 1
                          nextiteration:
                          Next j
                              Jared Huffman
                              That fixed it.  Thanks for the help.
                                  Nick Hayman
                                  Hi Jared,
                                  Very happy you've managed to work this out. Helps me a lot! Thank you.
                                  I have different configurations (linked to display states) where each configuration has different sub assemblies excluded from BOM. If I was to active configuration 1 would the drawings automatically change quantities? So If I was to click on configuration 2 would the drawing quantities then automatically update to that configuration?
                                  Basically if I activated one of my configurations would the drawing quantities update according to the configuration?
                                      Nick Hayman
                                      Santosh,
                                      Do I replace the code shown below in green with the code shown below in red/orange? Is this the idea?
                                      Code in the attached file on previous forum:
                                        cCnt = 0
                                            cCnt = cCnt + 1
                                        Next j
                                        CmpDoc.CustomInfo2(Cfg, "QtyIn") = Assembly.GetTitle & " Cfg " & Assembly.ConfigurationManager.ActiveConfiguration.Name
                                      Else
                                        NoUp = NoUp + 1
                                      Next i
                                      Assembly.Extension.ShowSmartMessage NoUp & " Parts not updated due to lightweight (" & timer - tm & "s)", 10000, True, True
                                      New Code:
                                      Sub UpdateQtys()
                                      Dim myCmps
                                      Dim Cfg As String
                                      Dim i As Long
                                      Dim j As Long
                                      Dim cCnt As Long
                                      Dim NoUp As Long
                                      Dim tm As Double
                                      tm = Timer
                                      Exit Sub
                                      NoUp = 0
                                      cCnt = 0
                                      If Boolstatus Then
                                      GoTo nextiteration
                                      Else
                                      cCnt = cCnt + 1
                                      nextiteration:
                                      Next j
                                      Else
                                      Else
                                      Else
                                      NoUp = NoUp + 1
                                      Next i
                                      Many Thanks
                                      Nick
