3 Replies Latest reply on Feb 23, 2014 8:50 AM by Deepak Gupta
    Get Custom Props from Excel-Write to Assy model
    Bernie Daraz
      OK, I hope I can ask for some help here as I've done as much as I can with my experience level.
      I'm trying to write a number of configuration specific custom properties to an assembly file for use in drawing automation. I'm pulling the data from an Excel file where I keep all the information on the models, part numbers, revisions, paint codes, ect. I currently have it working using the property tab builder but a bit more automation would help a lot and most likely prevent some transcription errors.
      I'm using SW 2012 for this project.
      I've copied and modified code from the web and have this:
          Set swModel = swApp.ActiveDoc
          Set xl = GetObject(, "Excel.Application")
          Set xlsh = xl.ActiveSheet
          PARTNUMBER = xlsh.Cells(1, 1)
          Revision = xlsh.Cells(1, 2)
          PartCode = xlsh.Cells(1, 3)
          Description = xlsh.Cells(1, 4)
          INVPART1 = xlsh.Cells(1, 5)
          FINLIST1 = xlsh.Cells(1, 6)
          INVPART2 = xlsh.Cells(1, 7)
          FINLIST2 = xlsh.Cells(1, 8)
          INVPART3 = xlsh.Cells(1, 9)
          FINLIST3 = xlsh.Cells(1, 10)
          INVPART4 = xlsh.Cells(1, 11)
          FINLIST4 = xlsh.Cells(1, 12)
          INVPART5 = xlsh.Cells(1, 13)
          FINLIST5 = xlsh.Cells(1, 14)
          INVPART6 = xlsh.Cells(1, 15)
          FINLIST6 = xlsh.Cells(1, 16)
          'Add the Custom Property Name with value. Will not overwrite if there is any existing property.
          swModel.AddConfiguration3 "PARTNUMBER", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(PARTNUMBER)
            retVal = swCustPropMgr.Add2("PARTNUMBER", swCustomInfoText, PARTNUMBER)
            swCustPropMgr.Set "PARTNUMBER", PARTNUMBER
          swModel.AddConfiguration3 "Revision", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Revision)
            retVal = swCustPropMgr.Add2("Revision", swCustomInfoText, Revision)
            swCustPropMgr.Set "Revision", Revision
          swModel.AddConfiguration3 "PartCode", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(PartCode)
            retVal = swCustPropMgr.Add2("PartCode", swCustomInfoText, PartCode)
            swCustPropMgr.Set "PartCode", PartCode
          swModel.AddConfiguration3 "Description", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Description)
            retVal = swCustPropMgr.Add2("Description", swCustomInfoText, Description)
            swCustPropMgr.Set "Description", Description
          swModel.AddConfiguration3 "INVPART1", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART1)
            retVal = swCustPropMgr.Add2("INVPART1", swCustomInfoText, INVPART1)
            swCustPropMgr.Set "INVPART1", INVPART1
          swModel.AddConfiguration3 "FINLIST1", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST1)
            retVal = swCustPropMgr.Add2("FINLIST1", swCustomInfoText, FINLIST1)
            swCustPropMgr.Set "FINLIST1", FINLIST1
          swModel.AddConfiguration3 "INVPART2", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART2)
            retVal = swCustPropMgr.Add2("INVPART2", swCustomInfoText, INVPART2)
            swCustPropMgr.Set "INVPART2", INVPART2
          swModel.AddConfiguration3 "FINLIST2", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST2)
            retVal = swCustPropMgr.Add2("FINLIST2", swCustomInfoText, FINLIST2)
            swCustPropMgr.Set "FINLIST2", FINLIST2
          swModel.AddConfiguration3 "INVPART3", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART3)
            retVal = swCustPropMgr.Add2("INVPART3", swCustomInfoText, INVPART3)
            swCustPropMgr.Set "INVPART3", INVPART3
          swModel.AddConfiguration3 "FINLIST3", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST3)
            retVal = swCustPropMgr.Add2("FINLIST3", swCustomInfoText, FINLIST3)
            swCustPropMgr.Set "FINLIST3", FINLIST3
          swModel.AddConfiguration3 "INVPART4", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART4)
            retVal = swCustPropMgr.Add2("INVPART4", swCustomInfoText, INVPART4)
            swCustPropMgr.Set "INVPART4", INVPART4
          swModel.AddConfiguration3 "FINLIST4", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST4)
            retVal = swCustPropMgr.Add2("FINLIST4", swCustomInfoText, FINLIST4)
            swCustPropMgr.Set "FINLIST4", FINLIST4
          swModel.AddConfiguration3 "INVPART5", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART5)
            retVal = swCustPropMgr.Add2("INVPART5", swCustomInfoText, INVPART5)
            swCustPropMgr.Set "INVPART5", INVPART5
          swModel.AddConfiguration3 "FINLIST5", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST5)
            retVal = swCustPropMgr.Add2("FINLIST5", swCustomInfoText, FINLIST5)
            swCustPropMgr.Set "FINLIST5", FINLIST5
          swModel.AddConfiguration3 "INVPART6", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(INVPART6)
            retVal = swCustPropMgr.Add2("INVPART6", swCustomInfoText, INVPART6)
            swCustPropMgr.Set "INVPART6", INVPART6
          swModel.AddConfiguration3 "FINLIST6", "", "-", 0
            Set swCustPropMgr = swModel.Extension.CustomPropertyManager(FINLIST6)
            retVal = swCustPropMgr.Add2("FINLIST6", swCustomInfoText, FINLIST6)
            swCustPropMgr.Set "FINLIST6", FINLIST6
          swModel.DeleteConfiguration2 "Default"
      It errors out and presents me with an Object varible error 91.
      I can see during debug that it successfully reads the Excel file and has the proper data associated with the custom property names but I see this at the break: (I imagine I would see this at every break.)
      I must have some stupid error here and I'm ready to give up. I would appreciate any and all help! Thanks!
        • Re: Get Custom Props from Excel-Write to Assy model
          Deepak Gupta
          Bernie are you sure you want to add configuration names based on the revision property. Because this line is doing so
          Further this line connects to that configuration.
          And I believe since your property name, property value name and configuration name are same, the macro is getting confued.
          If above is correct i.e. you need to add configurations also then try this modified/simplified code and share how it goes with you.
              PARTNUMBER1 = "123"
              Revision1 = "ABC"
                retVal = swCustPropMgr.Add2("PARTNUMBER2", swCustomInfoText, PARTNUMBER1)
                retVal = swCustPropMgr.Add2("Revision2", swCustomInfoText, Revision1)
          If not then share the exact need and I'll have the codes modified for you.
              Bernie Daraz
              Thanks Deepak!
              I modified the code to your suggestion and it works. The only issue now I see is that it is writing to custom properties and not configuration specific properties:
              I still have the Property Builder version that I use when I revise older files and reset the drawing formats, the inserted 'properties' do not appear there.
              I imagine the 'names' used to store and manipulate the values will change.
              The revision is used for the drawing only. I use Pack and Go to store and archive versions. If you need to edit a part (all parts are saved as assemblies) it is accessed from the top level drawing. This eliminates changing part names when revisions occur, though each part has a revision level as a custom property as well.
              Obviously writing macros is not my cup of tea, thanks again for your help.
              ___________
              On second thought it might be better to have the macro ENABLE overwriting of the existing peoperties.
              Message was edited by: Bernie Daraz
                  Deepak Gupta
                  Sorry Bernie, did read you original post clearly. The codes you had up there are for custom properties, so I had set them for custom properties only. Please try the following codes:
                  Option Explicit
                      Dim swApp               As SldWorks.SldWorks
                      Dim swModel             As SldWorks.ModelDoc2
                      Dim swConfigMgr         As SldWorks.ConfigurationManager
                      Dim swConfig            As SldWorks.Configuration
                      Dim swCustPropMgr       As SldWorks.CustomPropertyManager
                      Dim PARTNUMBER1         As String
                      Dim Revision1           As String
                      Dim PARTNUMBER2         As String
                      Dim Revision2           As String
                      Set swConfigMgr = swModel.ConfigurationManager
                      Set swConfig = swConfigMgr.ActiveConfiguration
                      Set swCustPropMgr = swConfig.CustomPropertyManager
                      PARTNUMBER1 = "123"
                      Revision1 = "ABC"
                      swModel.AddCustomInfo3 swConfig.Name, "PARTNUMBER2", swCustomInfoText, PARTNUMBER1
                      swCustPropMgr.Set "PARTNUMBER2", PARTNUMBER1
                      swModel.AddCustomInfo3 swConfig.Name, "Revision2", swCustomInfoText, Revision1
                      swCustPropMgr.Set "Revision2", Revision1
