4 Replies Latest reply on Feb 21, 2014 9:09 AM by Bryan Jenkins
    Enterprise PDM API
    Bryan Jenkins
      Anyone,
      We are trying to get information from our MRP/ERP, Work Order documents and other sources into variables on folder and file data cards.   This information (at the moment) is being processed by a VB.NET/EXE application. So we have the individual data strings separated by VB.NET variables.  But we are having problems setting the variable value for (folder/File Data card a object a  variable input).   Are we looking at this from the wrong direction? Or does someone know of a .dll call that we might not have looked at?
        • Re: Enterprise PDM API
          Artem Taturevych
          Are the files you are trying to set values to are checked out and are the variables you are trying to set are on Data Card. These are the required to make this work.
              Bryan Jenkins
              I have tryed both checked in and checked out just to see.
              Try
                          Dim vault2 As IEdmVault7 = Nothing
                          If vault1 Is Nothing Then
                              vault1 = New EdmVault5()
                          vault2 = DirectCast(vault1, IEdmVault7)
                          If Not vault1.IsLoggedIn Then
                              'Log into selected vault as the current user
                              vault1.LoginAuto(VaultsComboBox.Text, Me.Handle.ToInt32())
                          Dim aFile As IEdmFile6
                          aFile = vault2.GetFileFromPath(ListBox.Items(0).ToString())
                          'Get card variables only from a file checked into the vault
                          If Not aFile.IsLocked Then
                              aFile.LockFile(vault2.RootFolderID, Me.Handle.ToInt32(), EdmLockFlag.EdmLock_Simple)
                              Dim varEnum As IEdmEnumeratorVariable5
                              varEnum = aFile.GetEnumeratorVariable
                              Dim valueList() As Object = Nothing
                              varEnum.GetUpdateVars(aFile.LockedInFolderID, valueList)
                              Dim idx As Integer = 0
                              idx = LBound(valueList)
                              Dim upper As Integer
                              upper = UBound(valueList)
                              Dim msg As String
                              msg = "Card variables for " & aFile.Name & " in configuration, @:" & vbLf & vbLf
                              Dim varMgr As IEdmVariableMgr5
                              varMgr = aFile.Vault
                              Dim var As IEdmVariable5
                              Dim value As IEdmVariableValue5
                              While idx <= upper
                                  value = valueList(idx)
                                  idx = idx + 1
                                  var = varMgr.GetVariable(value.VariableID)
                                  msg = msg & value.VariableName & " = > " & value.GetValue("@").ToString() & vbLf
                                  msg = msg & "EdmVariableFlags: " & var.Flags & ", EdmVariableType: " & var.VariableType & vbLf & vbLf
                                  'msg = msg & "EdmVariableFlags: " & value.VariableFlags & ", EdmVariableType: " & value.VariableType & vbLf & vbLf
                              End While
                              MessageBox.Show(msg)
                              aFile.UndoLockFile(Me.Handle.ToInt32())
                          Else
                              'User selected a checked-out file
                              MessageBox.Show("Please select a checked-in file.")
                      Catch ex As System.Runtime.InteropServices.COMException
                          MessageBox.Show("HRESULT = 0x" + ex.ErrorCode.ToString("X") + " " + ex.Message)
                      Catch ex As Exception
                          MessageBox.Show(ex.Message)
                      End Try
                  Jim Sculley
                  GetUpdateVars is not what you want to use.  It is meant for situations where you are setting attributes (e.g. Custom Properties) in files that EPDM doesn't understand.  It doesn't have anything to do with data cards.
                  Plain vanilla setting of data card variables is done using either IEdmEnumeratorVariable8::SetVar or IEdmBatchUpdate::SetVar.
                  The API documentation for each of these interfaces has examples of how to use them.
                  Jim S.
                      Bryan Jenkins
                      That worked!!!!
                      Try
                                  Dim enumVariable As IEdmEnumeratorVariable8
                                  enumVariable = aFile.GetEnumeratorVariable(ListBox.Items(0).ToString())
                                  enumVariable.SetVar("ProjectNumber", "@", "12345")
                                  enumVariable.CloseFile(True)
                                  MessageBox.Show("Project Number set to " + "12345" + vbLf)
                              End Try
                      Thank You Very Much!!!!!!
