1 Reply Latest reply on Feb 21, 2014 11:30 AM by Mohammed Elkalakhi
    Checking option MergeFace doesn't work on flat pattern feature
    Mohammed Elkalakhi
      Hello eveybody,
      I have a metal sheet part, I test if the the option MergeFace is checked, if not I try to chek it but it doesn't work, I dont know why ?
      Here is my code :
      Sub Main()
              Dim swApp As SldWorks
              Dim swDoc As ModelDoc2
              Dim swFlatPatt As FlatPatternFeatureData
              Try
                  swApp = CreateObject("SldWorks.Application")
                  swDoc = swApp.ActiveDoc
                  Dim swSelectedFeature As Feature = GetFeatureByName("Etat déplié1", swDoc)
                  swFlatPatt = swSelectedFeature.GetDefinition()
                  If Not swFlatPatt.MergeFace Then swFlatPatt.MergeFace = True
              Catch ex As Exception
                  Debug.Print(ex.Message)
              End Try
              Console.Read()
          Function GetFeatureByName(ByVal _Name As String, swDoc As ModelDoc2) As Feature
              Try
                  For i As Integer = 0 To swDoc.GetFeatureCount - 5
                      Dim swFeature As Feature = swDoc.FeatureByPositionReverse(i)
                      If swFeature.Name.ToUpper = _Name.ToUpper Then
                          Return swFeature
                      Dim swSubFeature As Feature = swFeature.GetFirstSubFeature()
                      If swSubFeature Is Nothing Then Continue For
                      Do
                          If swSubFeature.Name.ToUpper = _Name.ToUpper Then
                              Return swSubFeature
                          swSubFeature = swSubFeature.GetNextSubFeature
                      Loop Until swSubFeature Is Nothing
                  Next
                  Return Nothing
                  Throw ex
              End Try
          End Function
      Thanks in advance.
