3 Replies Latest reply on Feb 20, 2014 9:13 AM by Chris Johnson
    works in VBA but not .NET
    Chris Johnson
      Hi All,
      any guesses as to why this doesnt work  in .NET? but it does in VBA
      FYI this is inside of a property Manager Page if that somehoe matters
      for some reason it thinks my edge is not outer but im selecting the end face of a pipe...
      Sub LoadStartFace()
              Dim swModel As ModelDoc2 = iSwApp.ActiveDoc
              Dim swselMgr As SelectionMgr = swModel.SelectionManager
              Dim swLoop As Loop2
              Dim swSelFace As Face2
              Dim vLoops As Object
              Dim vedges As Object
              Dim EdgeEntity As Entity
              Dim i As Long
              Dim j As Integer
              'Refine Selection to OD Edge
              swSelFace = swselMgr.GetSelectedObject6(1, -1)
              If Not swSelFace Is Nothing Then 'Verify a Face is Selected before moving on.
                  vLoops = swSelFace.GetLoops
                  swModel.ClearSelection2(True)
                  For i = 0 To UBound(vLoops)
                      swLoop = vLoops(i)
                      If swLoop.IsOuter Then
                          vedges = swLoop.GetEdges
                          For j = 0 To UBound(vedges)
                              EdgeEntity = vedges(j)
                              EdgeEntity.Select4(True, Nothing)
                          Next
                  Next
              Else
                  MsgBox("A Face Should be Selected at this point, program might be broken")
                  Exit Sub
      Thanks again!
      Chris
