AMAngus McLeod19/02/2014
I have come to a standstill while going through the EPDM API "Set Revisions" example in the API Fundamentals book.
I am writing the examples in C# even though they are presented in VB. I presume that these examples should work in both languages.
Error as follows:
"An unhandled exception of type 'System.ArgumentException' occurred in EPDM_SetRevision.exe
Additional information: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
The error seems to occur when calling the "SetRevisionCounters(fileObj.ID, revCounters)" method. See code below...
     // Assign the new revison counter value to the value stored in the Revision card variable
     // converted to an integer.
     long revInt = Strings.Asc(revisionProp.ToUpper()) - Strings.Asc("A") + 1;
     revCounters[0].mlCounter = (int)revInt;
     // Set the revision counter to the new values.
     revMgr.SetRevisionCounters(fileObj.ID, revCounters);
     // Set the revision of the file to the new values.
     revMgr.IncrementRevision(fileObj.ID);
Debug output:
A first chance exception of type 'System.ArgumentException' occurred in EPDM_SetRevision.exe
The program '[4748] EPDM_SetRevision.vshost.exe: Managed (v4.0.30319)' has exited with code -1 (0xffffffff).
Method prototype (COM):
HRESULT SetRevisionCounters( [in] long lFileID,
                             [in] SAFEARRAY ( struct EdmRevCounter ) poCounters );
Displays in VS2012 (C#) as:
void SetRevisionCounters(int lFileID, Array poCounters);
Has this happened to anyone else before? Any help would be most appreciated.
I am running EPDM and Solidworks 2013 and developing in Visual Studio Express 2012.
Am using WPF for my launch application.
Cheers
