I am tasked with creating step by step prints for manufacturing / machining operation, from a piece of raw stock to finished part.
My preferred method would be to create a "operations model", import geometry of the finished part that would be reference only wtih external links (construction geometry), extrude a solid over the reference geometry in the shape of the raw material, and then take extruded cuts by converting entities of the reference model, until I get back to the design part. (defining a configuration for each step of the machining process) In this way, my operations model maintains a link to the design model so that and any changes can flow down.
I have a feeling there is an easy way to do this, but I have not been able to find it ( I am admittedly a SW newbie)
When you created your extrude that surrounds the imported part you probably had "Merge result" selected in the PropertyManager. Right-click on that feature, choose the "Edit feature" icon, and if that box is checked then un-check it. After doing that and clicking OK, right-click on the feature in the tree again and choose "Change Transparency" from the drop-down. That should produce the desired result.
