I'm having an issue exporting sketch points in that the points that I'm interested in come along with extra data. When I create 3 points in space and I export the sketch I get 3 points in my txt file, but when I create 3 points defned by the object the txt file has between 3 and 9 points depending on the placement.
How can I export so that I only get the points I drew without the reference points also included?
It seems like all I have to do is CTRL+C CTRL+V the sketch in the tree before running the macro and that gets rid of all the relations for me
In case anyone esle needs it heres my finalized ish macro.
Select a sketch, run the macro.
It will make a copy of the sketch so the relations are all gone (i think) then save the .txt based on the name of the original. After its done it will delete the copy (hopefully). Works correctly with points only.
