I have a large assembly (1,000+ components).
I want to export and send to a customer so they can add it to there floor plan.
How can I remove as much internal detail as possible, leaving mainly the outside shell?
you have several options - results will vary depending on the specifics of your assembly. these two are likely to give the best results.
1. the defeature tool.
2. save as part - select option for external faces or external components.
