hi, I have an assignment to simulate the thermal stress on a pipe by thermal expansion, the result is made as the attached picture, but I am doubted as the highest stress is over yield stress too much, I am afraid if I have made some mistake so I post it to make a discussion:
pipe size: outer=90mm, insde=80mm, length=500mm
material: AISI 304
study: static
fixed: two surfaces including the bottom and the stand are fixed by "Fixed Gemotry"
external loads: whole solid temperature=50 Celsius, reference temp at zero strain=20 Celsius
mesh: default mesh density
result: max.stress=359.0MPa, max displacement=2.397e-001mm
So, based on this result, the pipe should be first deformed on the stand, but in real life it seems that most steel pipe could be heated to a higher temperature without deformation, so I am not sure if all my simulation steps are right. Please help to correct it if possible, thank you.
