1 Reply Latest reply on Feb 17, 2014 2:19 PM by Anna Wood
    Help with Batch plot routine
    Larry Blakely
      I have tried to write a batch plot routine to use Edrawings Axcontrol to plot drawing to PDF's.
      The currrent problem is after running a few prints I get HashStack errors...and the program closes.
      Can anyone offer me a clue as to how to prevent this.... or a better solution.
      Any help appreciated. Thanks.
      The basic print call is as follows
      For V_x As Integer = 0 To BomDataTable.Rows.Count - 1
                  If BomDataTable.Rows(V_x).Item("PartNum").ToString.Length = 12 Then
                      FileName2 = V_SaveFolder & "\TempJobs\" & BomDataTable.Rows(V_x).Item("PartNum") & ".SLDDRW"
                      If System.IO.File.Exists(FileName2) = False Then
                          MsgBox("File Not Found : " & FileName2)
                          Continue For
                      Me.Label4.Text = "Processing : " & BomDataTable.Rows(V_x).Item("PartNum")
                      Me.Label4.Refresh()
                      Fname = BomDataTable.Rows(V_x).Item("PartNum")
                      AxEModelViewControl1.Focus()
                      AxEModelViewControl1.OpenDoc(FileName2, False, False, True, "")
                      PDFPRINT2(Fname) 'Call Print Sub
                      AxEModelViewControl1.CloseActiveDoc("")
                      System.Threading.Thread.Sleep(1000)
                      Application.DoEvents()
                  Me.Label4.Refresh()
      Next V_x
      Private Sub PDFPRINT2(ByVal Name As String)
              V_TPageS = AxEModelViewControl1.SheetCount
              For V_x = 1 To V_TPageS + 1 'loop for the .drw files
                  AxEModelViewControl1.ShowSheet(V_x)
                  If V_x = V_TPageS + 1 Then
                      SName = AxEModelViewControl1.get_SheetName(0)
                      AxEModelViewControl1.ShowSheet(0)
                      W = AxEModelViewControl1.SheetWidth
                      H = AxEModelViewControl1.SheetHeight
                  Else
                      SName = AxEModelViewControl1.get_SheetName(V_x)
                  If W = 17 Then
                      PaperSize = PaperKind.Tabloid
                  ElseIf W = 11 Then
                      PaperSize = PaperKind.A4
                  AxEModelViewControl1.SetPageSetupOptions(EMVPrintOrientation.eLandscape, PaperSize, W, H, 1, 0, "PDFCreator", 0, 0, 0, 0)
                  AxEModelViewControl1.Print4(False, Name & SName, True, False, False, EMVPrintType.eScaleToFit, 0.0, 0, 0, False, V_x, V_x)
                  System.Threading.Thread.Sleep(500)
                  newcount = newcount + 1
                  Me.Label_PrntIts.Text = newcount
              Next
