I can not save the static analysis derived from the loads import of Motion.
When I open the part nothing appears to load and when is loading the part memory usage reaches 20 Gb
What version and service pack?
Does it happen on all files?
Are you able to run static analysis without motion import?
What is your workflow?
I am running Solidworks 2014 SP2
This happens on some files.
Yes I can run static analysis without motion imports, I can also run the static analysis with motion imports, but after saving the file to open the file it nothing appears.
what is unique about the files where the problem happens vs the ones that it doesn't?
i'm still nto clear what your workflow is.
