9 Replies Latest reply on Feb 14, 2014 8:28 PM by Simon Turner
    Is there a SW expert watching over the posts
    Tony Hong
      I am just wondering if there is a SW expert that can give correct answers to the questions posted on this forum?
        • Re: Is there a SW expert watching over the posts
          J. Mather
          I have seen a lot of Certified SolidWorks Experts (and Professionals, and others) watch over questions posted on this forum and provide correct answers.  Just look at the number of answers that were accepted by the original OPs asking the quesions.
          Do you have a specific thread  in mind (provide url)?
              Tony Hong
              I have been struggling with the following questions for days, but still can't solve them...
              https://forum.solidworks.com/message/410224#410224
              https://forum.solidworks.com/message/410130#410130
                  Simon Turner
                  I think Artem made some sensible suggestions.
                  Also, for your weldment profile point, I noticed this code:
                  boolstatus = swDoc.Extension.SelectByID2("Point27@Sketch11", "EXTSKETCHPOINT", 0, 0.20332700000000004, 0, true, 0, null, 0);
                  So, you are selecting the same point twice - therefore deselecting it.
                  For your second point, you didn't really give enough information to say more than Artem already said. You have to check the status of swDoc as soon as you create the new document. Check that it really is creating the file.
                      Tony Hong
                      Hi Simon,
                      Actually, it doens' matter how many times the point is selected. The selection function SelectByID2 returns "false" everytime. I don't know the reason.
                      I created a c# marco, and the same line doesn't work either...
                      Tony
                          Simon Turner
                          I wonder - you are effectively editing a feature when you use swWeldFeatData.AccessSelections
                          Maybe if you get the sketchpoint before calling AccessSelections it may work.
                              Tony Hong
                              I created a c# macro by recording the modeling process - first generate a structural beam, then change the profile location point. With this macro, a beam is created automatically, but the profile is by default located at the center point, not the point I specified.
                              I debug the macro project, the line which is samiliar to the one I developed in my program,
                              returns "false" too.
                              I didn't change anything after the macro project is created.
                              I wonder if SW has a bug there...
                                  Simon Turner
                                  I personally wouldn't select the point by name. Also, I don't think you actually need to select the point. You just need to get it from the list of sketch points returned by Sketch::GetSketchPoints2
                                  Here is a VBA macro which gets a sketch point from a sketch, given the known X and Y coordinates:
                                  Option Explicit
                                  Dim Part As ModelDoc2
                                  Dim mySketch As Sketch
                                  Dim boolstatus As Boolean
                                      Dim myPart As PartDoc
                                      Dim myFeat As Feature
                                      Dim myPoints As Variant
                                      Dim myPt As SketchPoint
                                      Dim i As Integer
                                      Dim mX As Double, mY As Double
                                      'Coordinates of desired point
                                      mX = 15 / 1000
                                      mY = 25 / 1000
                                      Set Part = swApp.ActiveDoc
                                      Set myPart = Part
                                      Set myFeat = myPart.FeatureByName("Sketch1") 'Or whatever your sketch is called (or use some other method of getting to the sketch - traverse the sub-features of your structural member)
                                      Set mySketch = myFeat.GetSpecificFeature2
                                      myPoints = mySketch.GetSketchPoints2
                                      For i = 0 To UBound(myPoints)
                                          Set myPt = myPoints(i)
                                          If Abs(myPt.X - mX) < 0.00001 And Abs(myPt.Y < mY) < 0.00001 Then 'This must be the point
                                              Exit For
                                      Next
                                      boolstatus = myPt.Select4(False, Nothing)
                              Tony Hong
                              Regarding the second question, the add-in works well when SW is run directly, not called from Visual studio. When I debug the program in VS, swDoc returns null, and the error info pops up.
                          Tim Webb
                          Agreed Tony
                          I've been struggling with the issue on this thread
                          https://forum.solidworks.com/thread/77758?tstart=0
                          But unfortunately the thread has received little attention. It is completely API related but is EPDM API so it did not make sense to post it in the EPDM area.
                          Anyway, yeah, I agree.
                          Tim Certified Enterprise PDM Administrator
                          equivaQ Software, LLC
                          http://www.equivaq.com
