I need an advice to simulate clamped part.
I have attached picture from SW.
The idea is that there are 3 stacked bricks, each weights 2.3kg.
The lower brick is clamped from both sides.
I need to know if the clamping force is enough to hold the bricks from falling.
How do I set up simulation correctly?
Thanks in advance!
Elgars,
You don't need Simulation to get a reasonable answer for this problem. It is a simple hand calculation using the coefficient of friction between your clamp and the brick.
Jerry S.
