I had a problem when I tried to mesh a shock absorber. It notice me that there are two bodies are interfering.
Please help me how to
The first set interfering faces are a pair of hole and shaft, both are 12.6mm diameter. The red area is the interfering faces
The second set interfering faces are the spring and plunger plate. They also has the same diameter on the interfering faces.
Thanks for your answer. I did enabled the " threat conincidence as interference"
Some other people told me I can try to compress the part which is not important to be analysed. And the problem was sorted out after I compressed the spring.
