3 Replies Latest reply on Feb 14, 2014 12:59 PM by Sam King
    Export Part as DWG/DXF Macro
    Sam King
      I am trying to export a face (with multiple holes of varying types) as a DXF file for our waterjet. I'm also creating/saving the DXF in a new folder named "Waterjet Files" In my code I select all the appropriate faces I want to export.  You can see in the pictures, that the counterbored/countersunk surfaces are not selected.  For some reason, when I export the DXF it is including those surfaces in the DXF file.  Does anybody know why it is doing this? (I'm also pretty new at programming so some of the code may not be that efficient, any suggestions for improvement would be greatly appreciated)
      Here is my code:
      Option Explicit
      Sub SelectFrontFace()
          Dim swApp                               As SldWorks.SldWorks
          Dim swMathUtility                     As SldWorks.MathUtility
          Dim swRefPlaneTransform     As SldWorks.MathTransform
          Dim swNormalVector          As SldWorks.MathVector
          Dim faceNormalVector        As SldWorks.MathVector
          Dim swNormalVectorRefPlane  As SldWorks.MathVector
          Dim swParallelCheck         As SldWorks.MathVector
          Dim swOriginPoint           As SldWorks.MathPoint
          Dim swOriginPointRefPlane   As SldWorks.MathPoint
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swPart                  As SldWorks.PartDoc
          Dim swBody                  As SldWorks.Body2
          Dim swSelMgr                As SldWorks.SelectionMgr
          Dim swFeature               As SldWorks.Feature
          Dim subFeature              As SldWorks.Feature
          Dim NextFeature             As SldWorks.Feature
          Dim swPlane                 As SldWorks.Feature
          Dim PlaneFeature            As SldWorks.Feature
          Dim mySurface               As SldWorks.Surface
          Dim FeatureData             As SldWorks.WizardHoleFeatureData2
          Dim refPlane                As SldWorks.refPlane
          Dim myFace                  As SldWorks.Face2
          Dim myEdge                  As SldWorks.Edge
          Dim goodEdge                As SldWorks.Edge
          Dim swSketch                As SldWorks.Sketch
          Dim HoleDim                 As SldWorks.Dimension
          Dim vConfNameArr            As Variant
          Dim vDimVal                 As Variant
          Dim HoleSize                As Variant
          Dim varAlignment            As Variant
          Dim varViews                As Variant
          Dim swFaceVar               As Variant
          Dim vEdges                  As Variant
          Dim vP1                     As Variant
          Dim vP2                     As Variant
          Dim swBodyVar               As Variant
          Dim planeParams             As Variant
          Dim vFaceNorm               As Variant
          Dim vPointData              As Variant
          Dim vVectorData             As Variant
          Dim FeatureCount            As Long
          Dim FastenerType            As Long
          Dim swNameSize              As Long
          Dim swPathSize              As Long
          Dim FeatureType             As String
          Dim swConfigName            As String
          Dim NextFeatureType         As String
          Dim sketchName              As String
          Dim FastenerSize            As String
          Dim swModelName             As String
          Dim swPathName              As String
          Dim dataViews(0)            As String
          Dim swFileName              As String
          Dim swFileNameNoExtension   As String
          Dim swPathNoExtension       As String
          Dim swNewFilePath           As String
          Dim swNewFileName           As String
          Dim refPlaneName            As String
          Dim dataAlignment(11)       As Double
          Dim dDist                   As Double
          Dim aPointData(2)           As Double
          Dim aVectorData(2)          As Double
          Dim VectorLength            As Double
          Dim i                       As Integer
          Dim j                       As Integer
          Dim faceCount               As Integer
          Dim edgeCount               As Integer
          Dim HoleType                As Integer
          Dim MyPlane                 As Object
          Dim FrontPlane              As Object
          Dim boolstatus              As Boolean
          Dim bShowConfig             As Boolean
          Dim bCoin                   As Boolean
          Dim surf                    As Boolean
          Set swMathUtility = swApp.GetMathUtility
          Set swModel = swApp.ActiveDoc
          Set swPart = swModel
          Set swFeature = swPart.FirstFeature
          swModel.ClearSelection2 True
          vConfNameArr = swModel.GetConfigurationNames
          If UBound(vConfNameArr) > 0 Then
                  swConfigName = vConfNameArr(1)
              ElseIf UBound(vConfNameArr) > 1 Then
                  MsgBox ("Too Many Configurations")
              Exit Sub
              Else
                  swConfigName = "Default"
          bShowConfig = swModel.ShowConfiguration2(swConfigName)
          Set PlaneFeature = swPart.FeatureByName("FRONT")
          refPlaneName = PlaneFeature.Name
          Set refPlane = PlaneFeature.GetSpecificFeature2
          Set swRefPlaneTransform = refPlane.Transform
          aPointData(0) = 0#
          aPointData(1) = 0#
          aPointData(2) = 1#
          vPointData = aPointData
          Set swOriginPoint = swMathUtility.CreatePoint(vPointData)
          Set swOriginPointRefPlane = swOriginPoint.MultiplyTransform(swRefPlaneTransform)
          vPointData = swOriginPointRefPlane.ArrayData
          aVectorData(0) = 0#
          aVectorData(1) = 0#
          aVectorData(2) = 1#
          vVectorData = aVectorData
          Set swNormalVector = swMathUtility.CreateVector(vVectorData)
          Set swNormalVectorRefPlane = swNormalVector.MultiplyTransform(swRefPlaneTransform)
          vVectorData = swNormalVectorRefPlane.ArrayData
          boolstatus = swPart.Extension.SelectByID2("FRONT", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
          Set MyPlane = swSelMgr.GetSelectedObject6(1, -1)
          swBodyVar = swPart.GetBodies2(swSolidBody, False)
          Set swBody = swBodyVar(0)
          swFaceVar = swBody.GetFaces
          For faceCount = 0 To UBound(swFaceVar)
              Set myFace = swFaceVar(faceCount)
              bCoin = True
              vEdges = myFace.GetEdges
              dDist = swModel.ClosestDistance(MyPlane, myFace, vP1, vP2)
                  If dDist > 0 Then
                      bCoin = False
              Set mySurface = myFace.GetSurface
              surf = mySurface.IsPlane
              planeParams = mySurface.planeParams
              vFaceNorm = myFace.Normal
              Set faceNormalVector = swMathUtility.CreateVector(vFaceNorm)
              Set swParallelCheck = swNormalVectorRefPlane.Cross(faceNormalVector)
              VectorLength = swParallelCheck.GetLength
              If VectorLength = 0 Then
                  If surf Then
                      If bCoin Then
                          myFace.Select True
          Next faceCount
          swModelName = swModel.GetPathName
          swPathName = swModel.GetPathName
          swPathSize = Strings.Len(swPathName)
          swPathNoExtension = Strings.Left(swPathName, swPathSize - 17)
          swNewFilePath = swPathNoExtension & "Waterjet Files\"
          If Len(Dir(swNewFilePath, vbDirectory)) = 0 Then
              MkDir (swNewFilePath)
          swFileName = swModel.GetTitle
          swNameSize = Strings.Len(swFileName)
          swNewFileName = Strings.Left(swFileName, swNameSize - 6)
          swPathName = Left(swPathName, InStrRev(swPathName, "\"))
          swPathName = swNewFilePath & swNewFileName & "dxf"
          dataAlignment(0) = 0#
          dataAlignment(1) = 0#
          dataAlignment(2) = 0#
          dataAlignment(3) = 1#
          dataAlignment(4) = 0#
          dataAlignment(5) = 0#
          dataAlignment(6) = 0#
          dataAlignment(7) = 0#
          dataAlignment(8) = 0#
          dataAlignment(9) = 0#
          dataAlignment(10) = 1#
          dataAlignment(11) = 0#
          varAlignment = dataAlignment
          dataViews(0) = ""
          varViews = dataViews
          swPart.ExportToDWG swPathName, swModelName, 2, True, varAlignment, False, False, 0, Null
        • Re: Export Part as DWG/DXF Macro
          Gustavo Oliveira
          Try this:
          Option Explicit
              Dim vP1                     As Variant
              Dim vP2                     As Variant
              Dim dDist                   As Double
              Dim i                       As Integer
              Dim j                       As Integer
              Dim surf                    As Boolean
                  Exit Sub
                  Else
              aPointData(0) = 0#
              aPointData(1) = 0#
              aPointData(2) = 1#
              aVectorData(0) = 0#
              aVectorData(1) = 0#
              aVectorData(2) = 1#
              swModel.ClearSelection2 True 'Add this code to clear all selection
                  bCoin = True
                      If dDist > 0 Then
                          bCoin = False
                      If surf Then
                          If bCoin Then
                              myFace.Select True
              Next faceCount
             If Dir(swPathName) <> "" Then Kill swPathName 'Add this code to delete the file if it already exists
              dataViews(0) = ""
