Hello;
I have a SW drawing, & we inserted a jpeg; (Insert Picture), into the drawing, & in that it was basically ok. When finished, I then did the saveas a dxf, & a dwg.
The inserted jpeg apparently gets exported as a bitmap, & you can't see it in the dxf or dwg. You see like the link to the file, if you D.C. on it, you are taken to the picture.
What we'd like is if when they opened up the file, they just saw the flow chart, not links to it. Is there a way to get around this?
Thanks, in advance for any input;
Rob_D SW; 2014 Sp2
