11 Replies Latest reply on Feb 21, 2014 10:19 AM by Kevin Tate
    Copy summary property to custom property
    Kevin Tate
      I've been trying to figure this out myself for a while now but I'm getting no where fast. I am trying to copy the information contained within the summary properties fields in a model to a specific custom property using a macro. I need to do this as I am trying to update a lot of old models.
      I have hashed together code I have found o nthe internet and come up with the following:
      Dim swApp As Object
          Dim swApp             As SldWorks.SldWorks
          Dim swModel          As SldWorks.ModelDoc2
          Dim swCustProp     As CustomPropertyManager
          Dim val                   As String
          Dim valout              As String
          Dim bool                As Boolean
          Dim swSumInfoTitle      As Integer
          Set swModel = swApp.ActiveDoc
          Set swCustProp = swModel.Extension.CustomPropertyManager("")
          valout = instance.SummaryInfo(swSumInfoTitle)
          bool = swCustPropMgr.Add("Description", True, val, vaout)
          swModel.ForceRebuild3 (False)
          swModel.Save
      It doesn't work though. I have been able to get the code to copy in the other direction (From custom property to summary property) using the following code:
      Dim swApp As Object
          Dim val                   As String
          Dim bool                As Boolean
          bool = swCustProp.Get4("Description", False, val, valout)
          swModel.SummaryInfo(swSumInfoTitle) = valout
          swModel.Save
      Any help resolving this would be most apriciated!
      Kevin
        • Re: Copy summary property to custom property
          Matt Martens
          You want to place the string to be entered in the val argument, not the valout. The valout is read-only because the software evaluates whatever has been entered into the val field.
            Kevin Tate
            I just thought I would post an update. I've used some other code I found else ware to add to the previous code to create a macro that loops through all files in a folder and copies text from multiple locations to the new custom properties. Thought this may be useful to anyone else searching this subject.
            Kevin
            Dim swApp As Object
            Dim Part As Object
            Dim boolstatus As Boolean
            Dim swApp0 As SldWorks.SldWorks
            Const strFolderPath As String = "C:\custom\"
            Dim strFileName As String
            Dim SumTitle As String
            Dim SumAuthor As String
            Dim SumSubject As String
            Dim OldPartNo As String
            Dim CustTitle As String
            Dim CustAuthor As String
            Dim CustSubject As String
            Dim CustPartNo As String
            Sub main0()
                Set swApp0 = Application.SldWorks
                strFileName = Dir(strFolderPath & "*.SLDPRT")
                While strFileName <> ""
                    Set swModel = swApp0.OpenDoc6(strFolderPath & strFileName, swDocPART, 1, Empty, Empty, Empty)
            'Old Properties
                SumTitle = swModel.SummaryInfo(swSumInfoTitle)
                SumAuthor = swModel.SummaryInfo(swSumInfoAuthor)
                SumSubject = swModel.SummaryInfo(swSumInfoSubject)
                OldPartNo = swModel.CustomInfo("SW-Part Number")
            'New Properties
                CustTitle = swModel.CustomInfo("[SW-Title]")
                CustAuthor = swModel.CustomInfo("Author")
                CustSubject = swModel.CustomInfo("[SW-Subject]")
                CustPartNo = swModel.CustomInfo("[SW-Part Number]")
            'Title Convert
                CustTitleValue = CustTitle
                If CustTitleValue <> "" Then
                CustTitle = SumTitle
                Else
                swModel.AddCustomInfo3 "", "[SW-Title]", swCustomInfoText, SumTitle
            'Author Convert
                CustAuthorValue = CustAuthor
                CustAuthor = SumAuthor
                Else
                swModel.AddCustomInfo3 "", "Author", swCustomInfoText, SumAuthor
            'Subject Convert
                CustSubjectValue = CustSubject
                CustSubject = SumSubject
                Else
                swModel.AddCustomInfo3 "", "[SW-Subject]", swCustomInfoText, SumSubject
            'Part Number Convert
                CustPartNoValue = CustPartNo
                CustPartNo = OldPartNo
                Else
                swModel.AddCustomInfo3 "", "[SW-Part Number]", swCustomInfoText, OldPartNo
                    swModel.Save3 1, Empty, Empty
                    swApp0.QuitDoc swModel.GetTitle
                    strFileName = Dir
                Wend
                swApp0.ExitApp
