1 Reply Latest reply on Feb 13, 2014 9:45 PM by Gustavo Oliveira
    What is the best way to insert a sketch
    Jamie Lill
      I have created a cylinder with APi. I want to insert a sketch on the end of the cylinder and cut extrude thru the hole body..
      There are two parts to this question
      (1) What is the best way to identify the face It was created at 0,0,0.
      (2) I have 50 standard but dissimilar shapes that I want to create.
           I could create a form with a button or listbox to draw each shape
           or should I put these shapes into some sort of data table.
      The shapes might have 20 lines for the most common to 1 circle to he simplest
      If you have any examples that would be great
        • Re: What is the best way to insert a sketch
          Gustavo Oliveira
          Try this macro: This macro will create a body and a hole using the same plane.
          Dim swApp As Object
          Dim Part As Object
          Set Part = swApp.ActiveDoc
          ' Create Body Circle
          Part.ClearSelection2 True
          Part.Extension.SelectByID2 "Front", "PLANE", 0, 0, 0, False, 0, Nothing, 0
          Part.SketchManager.CreateCircle 0#, 0#, 0#, 0.016, 0#, 0#
          ' Create Body Extrusion
          Part.FeatureManager.FeatureExtrusion2 True, False, False, 0, 0, 0.01, 0.01, False, False, False, False, 0, 0, False, False, False, False, True, True, True, 0, 0, False
          Part.SelectionManager.EnableContourSelection = False
          ' Create Hole Circle
          Part.SketchManager.CreateCircle 0#, 0#, 0#, 0.008, 0#, 0#
          ' Create Hole Extrusion
          Part.FeatureManager.FeatureCut3 True, False, True, 1, 0, 0, 0, False, False, False, False, 0, 0, False, False, False, False, False, True, True, True, True, False, 0, 0, False
