2 Replies Latest reply on May 6, 2014 9:01 AM by Jacob Corder
    API MacroFeature Security Function. Cannot Get MacroFeatureData Object.
    Jacob Corder
      I am writing an application using macrofeatures that is using a COM Server, not a vba macro. everything works great until i try to get the MacroFeatureData object in the security function. Once i call IFeature.GetDefinition, it recursiveley calls itself forever. whats the deal with that. according to the API Help, the security function can get the IMacrofeatureData Object from the supplied Feature Object.
      I am assuming i have to tell it not to check for security all of the time but i have to set security based on some values stored in the MacroFeatureData Object.
      i have this code in the function to allow temporary disabling of the feature but i really don't like it.
      I am just checking the type of MacroFeature that i have defined, then i am seing if it is required as stored in the Parameters.
      if it is required then i am returning swMacroFeatureSecurityOptions_e.swMacroFeatureSecurityCannotBeDeleted
      Dim DisableSecurity as boolean = false
      Dim SecurityCheck as integer = 0
      Public Function Security(ByVal app As Object, ByVal modelDoc As Object, ByVal feature As Object) As Object Implements SolidWorks.Interop.swpublished.ISwComFeature.Security
              Security = swMacroFeatureSecurityOptions_e.swMacroFeatureSecurityByDefault
              If SecurityCheck > 1 And DisableSecurity = False Then
                  DisableSecurity = True
              If DisableSecurity = False Then
                  Dim MacFeatData As MacroFeatureData = feature.GetDefinition
                  SecurityCheck = 0
                  If IsNothing(MacFeatData) = False Then
                      Dim Req As String = "FALSE"
                      Dim FeatType As Integer
                      MacFeatData.GetIntegerByName(JEMFeatures.CFeatureType, FeatType)
                      If FeatType = JEMEnum.MacroFeatureType_e.Child Then
                          MacFeatData.GetStringByName(JEMFeatures.ChildRequired, Req)
                          If UCase(Trim(Req)) = "TRUE" Then
                              Return swMacroFeatureSecurityOptions_e.swMacroFeatureSecurityCannotBeDeleted
              Else
                  SecurityCheck = SecurityCheck + 1
          End Function
      Any ideas on a better way would be great.
        • Re: API MacroFeature Security Function. Cannot Get MacroFeatureData Object.
          Jacob Corder
          Does anyone have any ideas or recommendation for me on this?
              Jacob Corder
              Ok so what i have done is in the COMServer that implements SwComFeature i have added a trigger to allow bypass of retrieval of the MacroFeatureData object
              I have a boolean value in my MacroFeatureData object that is named "Required"
              i have a local Variable Called DisableSecurityCheck this is what i set to true or false
              I have a Local Variable Called RegenCalling and EditCalling which are set to true once the Edit function is called and when the Regen Function is called. they are returned to false once those functions are done.
              During Normal Operation the security function will get called from Solidworks. beforei try to get the MacroFeatureData object, i set DisableSecurity to True. Once i get the macroFeatureData object i set it to False.
              what this does is it stops solidworks from calling the Security Function Over and over indefinately.
              This then allows me to set the feature as a non deleteable feature.
              All of my MacroFeatures have a parent unless it is the parent feature. i check for this with Feature.GetownerFeature
                      If RegenCalling = False And EditCalling = False Then
                          If SecurityCheck > 2 Then
                              SecurityCheck = 0
                          If DisableSecurity = True Then
                          ElseIf DisableSecurity = False Then
                              Try
                                  Dim Req As String = "False"
                                  Dim FeatType As Integer = 0
                                  'Set The Feature Obeject to Type of Feature
                                  With TryCast(feature, Feature)
                                       'Check to see if it is a child Feature
                                      If IsNothing(.GetOwnerFeature) = False Then
                                         'Disable Security to allow for getting the MacroFeatureData Object
                                          'Get the MacroFeatureDataObject
                                          With TryCast(.GetDefinition, MacroFeatureData)
                                             'Get The FeatureType which is a stored value that i have added to the MacroFeatureData Object
                                              .GetIntegerByName("COM Feature Type", FeatType)
                                              'I have many MacroFeatureTypes
                                              Select Case FeatType
                                                  Case MacroFeatureType_e.Child
                                                      'Check to see if it is Required
                                                      .GetStringByName("Required, Req)
                                                  Case MacroFeatureType_e.Appearance, MacroFeatureType_e.WaxFill
                                                      'These Features are always Required
                                                      Req = "TRUE"
                                              End Select
                                          End With
                                  End With
                                      'Set The Security to Non Deleteable
                                      Security = swMacroFeatureSecurityOptions_e.swMacroFeatureSecurityCannotBeDeleted
                             Catch Ex as Exception
                              Finally
                             'Ensure that the Security is set to False
                                  SecurityCheck = 0
                              End Try
                      Return Security
                  End Function
