6 Replies Latest reply on Feb 11, 2014 5:10 PM by Tony Hong
    How to change the profile locate point for a structural member
    Tony Hong
      Hi All,
      Usually, a structural member is located at the center point of its profile. I am tring to move it to another point on the profile. What I coded is listed in the following, but it doesn't work. Can anyone let me know the solution?
      Tony
                  //Structural feature is created, and by default located at the center point of the profile
                  myFeature = ((Feature)(swDoc.FeatureManager.InsertStructuralWeldment4("O:\\Solidworks\\Stealth Templates\\Weldment Profiles\\ansi inch\\W Section\\W16x40.sldl"                                   + "fp", 1, true, vGroups)));
                  swDoc.ClearSelection2(true);
                  //Get Structural member feature data
                  StructuralMemberFeatureData swWeldFeatData = (StructuralMemberFeatureData)myFeature.GetDefinition();
                  swWeldFeatData.AccessSelections(swDoc, null);
                  //Get the points that the structural member will be relocated
                  boolstatus = swDoc.Extension.SelectByID2("Point27@Sketch11", "EXTSKETCHPOINT", 0, 0.20332700000000004, 0, true, 0, null, 0);
                  SketchPoint swSketchPt1 = (SketchPoint)swDoc.ISelectionManager.GetSelectedObject(1);
                  SketchPoint swSketchPt2 = (SketchPoint)swDoc.ISelectionManager.GetSelectedObject(2);
                  //SketchPoint swSketchPt2 = (SketchPoint)swDoc.ISelectionManager.GetSelectionPoint(2);
                  //Set the property of LocatProfilePoint to the specified points
                  object[] wGroups = (object[])swWeldFeatData.Groups;
                  StructuralMemberGroup wGroup1 = (StructuralMemberGroup)wGroups[0];
                  wGroup1.LocateProfilePoint = swSketchPt1;
                  StructuralMemberGroup wGroup2 = (StructuralMemberGroup)wGroups[1];
                  wGroup2.LocateProfilePoint = swSketchPt2;
                  swWeldFeatData.ReleaseSelectionAccess();
                  //Implment the modification
                  myFeature.ModifyDefinition(swWeldFeatData, swDoc, null);
