When using INVENTOR, I can choose to have multiple instances of the same component inserted into the assembly, oriented the same way. From there, I use constraints to align the components to their proper locations.
Can the same be done with SOLIDWORKS?
Once the components are brought into the assembly, I'd still use constraints to properly place them, but when inserting multiple components, it would be nice to have them already turned around, facing the proper direction, leaving me with just having to use 1 or 2 constraints.
Bring in the first instance and orient it the way you want it. Once done, ctrl+left click and drag the instance from the tree into the graphics area. Another instance of the component will be created, oriented the same way as the first. This eliminates the whole copy & paste thing.
