Hello All,
I just installed SW 2007 X64 as an admin image on our network. It installs fine on all clients, (as a separate install, we also run 2006 SP 5.0)
2006 still works fine, but I can't get 2007 running! I updated to SP2.2 and Cosmos 2.0, still no luck.
What does the codes (-85,147,0) mean?
Flemming
Flemming
Don't know what you mean by order, we have the old 2006 admin image; I just made a new r:\admin2007x64 dir and installed the image there. Seems to work fine except from the license problem.
Don't know that SNL is..?
/Flemming
Thanks all!
/Flemming
EDIT: Where do I find this updated FlexLM install? Can I just install it upon the old install?
I forget if you require an updated snl_license.txt or not. :-)
Sorry again for the mix up.
Flemming
Just to make sure, we have Fluent running on the same FlexLM server, will this have any influence on them?
Flemming
INCREMENT solidworks SW_D 15.0 31-dec-2099 19 OVERDRAFT=0 SUPERSEDE \
The number after SW_D indicates the version that the license file is for - 15.0 is SW2007, 14.0 is SW2006.
Also, as has already been stated, install the 2007 SNL from the CD/DVD to ensure that you have the latest vendor daemons for Flex. This *shouldn't* have any effect on other Flex licenses - we have 7 non-Solidworks products that are managed by the one license server and they all ran OK after I installed the 2007 license manager.
Regards
Martin
Someone please correct me if I'm wrong.
Regards,
Richard.
