0 Replies Latest reply on Feb 20, 2014 12:17 PM by Craig Makarowski
    How do I set the Custom Property Tab Template from a VB Macro?
    Craig Makarowski
      Can't seem to record macro of when you select a Custom Property Template
      Now I select the template
      then i get this
      All the while I'm recording the Macro, even after I click the Apply button and Save!
      This is what i get in the Macro
      So none of the Property tab template functionallity gets recorded, I need to be able to control this in my Main Macro
      that has a form with values that would auto fill the fields in the Property tab. I can fill in the Custom properties directly from
      exsisting code but no Idea how to set the Property Tab Template from my VB code.
      I'm using SW2013 SP05 x64bit On Win7
