4 Replies Latest reply on Feb 11, 2014 9:51 AM by Craig Makarowski
    Can get custom propertiesfrom new active doc, but not set them!
    Craig Makarowski
      Hello all, I'm trying to set Custom properties from my custom macro.
      I can get a Custom property , but when i try to set a custom property I have no working result.
      I have looked in the API's for help and not found or undestand the answers/examples. After i have created teh Part document as rename and saved it
      I want to copy some of the fields in the form and from varibles into the Custom properties. Or into the Custom Property Tab interface as an alternate.
      Either way will work. the swCustProp.set2() method seem to always error out with runtime error 438 (Object doesn't support this property or method)
      Am I missing something here?
      Declarations
      Option Explicit
      'Define objects
      Dim Part As Object
      Dim rs As Object
      Dim OpenConnection As Object
      Dim objFields As Object
      Dim swApp As sldworks.sldworks
      Dim swModel As ModelDoc2
      Dim swModelDocExt As ModelDocExtension
      Dim swCustProp As Object 'CustomPropertyManager
      Dim val1 As String
      Dim PathName  As String
      Dim Filepath  As String
      Dim valout As String
      Dim bool As Boolean
      Dim partnumber As String
      Dim boolstatus As Boolean
      Here is my code snipet
          'Open a new design in solidworks and renames file and saves to working directory
      Sub createnewpart()
      'Dim instance As ICustomPropertyManager
      Dim FieldName As String
      Dim FieldValue As String
      Dim valuert As Integer
              If UserForm1.DocTypeLabel.Caption = ".SLDASM" Then
              Set swModel = swApp.NewAssembly()
              If (UserForm1.DocTypeLabel.Caption = ".SLDPRT") Then
              Set swModel = swApp.NewPart()
              'If (UserForm1.DocTypeLabel.Caption = ".SLDDRW") Then Set swModel = swApp.NewDrawing
              Set swModelDocExt = swModel.Extension
              ' Get the custom property data
              FieldName = "PART_NUMBER"
              FieldValue = UserForm1.NewCategoryTextBox.Value + "-" + UserForm1.NewCatindexTextBox.Value
              'valuert = swCustProp.Add3(FieldName, swCustomInfoText, FieldValue, 2)
              'swCustProp.Set "PART_NUMBER" = newfilename1
              'swCustProp.Get2 "PART_NUMBER", val1, valout
              'PathName = "C:\PDM_working"
              'PathName = swModel.GetPathName     'this gets the full path of the current open document (including filename)
              Debug.Print "Path name = " + PathName, "File name= " + newfilename1
              Filepath = PathName + "\" 'uses to full pathname to get the folder path, to be added to the save as file name
              If (swModel.GetType = swDocASSEMBLY) Then
                  swModel.SaveAs (Filepath + newfilename + ".sldasm")
              ElseIf (swModel.GetType = swDocPART) Then
                   swModel.SaveAs (Filepath + UserForm1.NewCategoryTextBox.Value + "_" + UserForm1.NewCatindexTextBox.Value + ".sldprt")
              Set swModel = swApp.ActiveDoc
              Set swCustProp = swModelDocExt.CustomPropertyManager("")
              Debug.Print "VAL1= " + val1, "Valout = " + valout 'this works
              valuert = swCustProp.Set2(FieldName, newfilename1)  'this dosen't set the PART_NUMBER custom property!
