Hello there,
I have had some problems to build a macro that generates flats patterns from a multibody part... In the API Help says that "ExportFlatPatternView" method belongs to IpartDoc Interface. So, if I have a multibody sheetmetal part and obtain an array of bodies from the cut list for example(or I use selectionmanager method), How can I storage each body in the Sldworks.Modeldoc2 variable type? what method or object have I to use?
All of the examples what i found are like this:
Sub Example ()
Dim swApp as SLdworks.Sldworks = Application.SLdworks
Dim part as Sldworks.ModelDoc2 = swApp.ActiveDoc
..... 'Some lines more
boolstatus = part.ExportFlatPatternView("C:\Users\xxxxx\xxxx\xxx.DXF", swExportFlatPatternOption_None)
.... ' lines
I need that "part" (Sldworks.Modeldoc2) be any body in my model or each body (in case that I use a "For.. Next" statement to sweep the array of bodies.)
Do you have any idea how i can solve this?
Thanks in advance
Regards
