Hello everyone, Good Day; I am simulating a heat transfer problem , for this i have to specify the initial tempearture of my part(As attached). the part is only a part file of solid works without any assembly. When i want to specify the initial temp, i have only access to select different faces . but i want to specify the whole body not only the faces. I will be grateful if anyone can give some suggestions to solve the problem. Thank you.
turn on selection filters
enable body selection
select body
