6 Replies Latest reply on Feb 10, 2014 7:42 AM by Jared Huffman
    How to Copy Project Name from Assembly to All Parts and Subassemblies
    Jared Huffman
      I design vey specialized equipment, so the part numbers and properties are project-specific.  I show the project name on the drawing of each component to help keep them organized.
      Currently, I use custom properties generated from the Property Tab Builder to assign all the various properties for each component or subassembly.  However, the project name is the same on every drawing, so it is not a good idea to enter it every single time.
      To reduce that repetition, I use Advanced Select (searching for SLDPRT) from the top level assembly and assign the project name property to all parts at once.  Then I repeat that for all subassemblies (searching for SLDASM), and then once again for the top level assembly because advanced select doesn't include that.
      Is there a way to only enter the project name once rather than three times?
      Thank you so much for any help you can offer!
        • Re: How to Copy Project Name from Assembly to All Parts and Subassemblies
          Chase Draper
          Alin Vargatu did a presentation about this at world but i think advance select only drops down one level.  If you can find him on here and shoot him a message i'm sure he would be the best to ask
            Deepak Gupta
            Welcome to SolidWorks forums Jared.
            Here is a macro you can look at https://forum.solidworks.com/message/128301#128301
            You might also find this post helpful for your future reference.
                Jared Huffman
                Thanks for the help! I wasn't able to find a single post that answers my question; that's why I started this thread. I am very new to VBA and using macros with SolidWorks, so it is difficult to troubleshoot any issues that come up.
                I will keep trying. I should be able to combine this post about how to write to a property (https://forum.solidworks.com/message/128301#128301) with a post about how to get a specific property value (https://forum.solidworks.com/message/366446#366446) and a post that works within an assembly to write a custom property to all the subcomponents (https://forum.solidworks.com/message/255198).
                I will update this thread on how it goes. Thanks again.
                    Jared Huffman
                    The macro is working now.
                    It does these 3 things:
                    1. Add assembly quantity property to each component
                    2. Add stock description property to each component
                    3. Copy the project title entered at the top level assembly to each component
                    #3 is the one I was adding via this thread.  Thanks again for the help!
                    FYI I referenced 3 posts:
                    ''Originally an equation built by Josh Brady of the Solidworks Forums
                    ''WILL AUTO SUM THE QUANTITY OF UNIQUE PARTS IN ALL ASSEMBLIES WHEN RAN FROM THE TOP ASSEMBLY.
                    ''CURRENTLY NEED TO MANUALLY ADD CUSTOM PROPERY 'Cfg4Qty'-'Text'-'Default' TO TOP LEVEL ASSEMBLY BEFORE RUNNING
                    Sub UpdateQtys()
                    Dim swApp As SldWorks.SldWorks 'added this line
                    Dim Assembly As ModelDoc2 'added this line
                    Dim myAsy As AssemblyDoc
                    Dim myCmps
                    Dim Cfg As String
                    Dim CmpDoc As ModelDoc2
                    Dim i As Long
                    Dim j As Long
                    Dim cCnt As Long
                    Dim NoUp As Long
                    Dim myCmp As Component2
                    Dim tCmp As Component2
                    Dim ProjTitle As String 'The variable for storing the assembly Project Title
                    Dim tm As Double
                    tm = Timer
                    Set swApp = Application.SldWorks 'added this line
                    Set Assembly = swApp.ActiveDoc 'added this line
                    Set myAsy = Assembly
                    If Assembly.ConfigurationManager.ActiveConfiguration.name <> Assembly.CustomInfo2("", "Cfg4Qty") Then
                    Assembly.Extension.ShowSmartMessage "Qtys not updated due to config", 1000, True, True
                    Exit Sub
                    ProjTitle = myAsy.CustomInfo2(Cfg, "ProjectTitle") 'Read the project title from the assembly
                    NoUp = 0
                    myCmps = myAsy.GetComponents(False)
                    For i = 0 To UBound(myCmps)
                    Set myCmp = myCmps(i)
                    If (myCmp.GetSuppression = 3) Or (myCmp.GetSuppression = 2) Then
                    cCnt = 0
                    Set CmpDoc = myCmp.GetModelDoc
                    Cfg = myCmp.ReferencedConfiguration
                    For j = 0 To UBound(myCmps)
                    Set tCmp = myCmps(j)
                    If tCmp.GetSuppression <> 0 Then
                    If tCmp.GetModelDoc2 Is CmpDoc Then
                    If tCmp.ReferencedConfiguration = Cfg Then
                    cCnt = cCnt + 1
                    Next j
                    CmpDoc.AddCustomInfo3 Cfg, "AutoQty", 30, ""
                    CmpDoc.AddCustomInfo3 Cfg, "QtyIn", 30, ""
                    CmpDoc.CustomInfo2(Cfg, "AutoQty") = cCnt
                    CmpDoc.CustomInfo2(Cfg, "QtyIn") = Assembly.GetTitle & " Cfg " & Assembly.ConfigurationManager.ActiveConfiguration.name
                    ''Added Stock Description Custom Property to be used in BOM
                    CmpDoc.AddCustomInfo3 Cfg, "StockDescription", 30, ""
                    CmpDoc.CustomInfo2(Cfg, "StockDescription") = "$PRP:" & Chr(34) & "HasDiameter" & Chr(34) & "$PRP:" & Chr(34) & "StockThickness" & Chr(34) & "$PRP:" & Chr(34) & "HasWidth" & Chr(34) & "$PRP:" & Chr(34) & "StockWidth" & Chr(34) & "$PRP:" & Chr(34) & "HasWall" & Chr(34) & "$PRP:" & Chr(34) & "StockWall" & Chr(34) & " x $PRP:" & Chr(34) & "StockLength" & Chr(34) & " LG"
                    ''Added Project Title Custom Property as read from assembly
                    CmpDoc.AddCustomInfo3 Cfg, "ProjectTitle", 30, ""
                    CmpDoc.CustomInfo2(Cfg, "ProjectTitle") = ProjTitle
                    Else
                    NoUp = NoUp + 1
                    Next i
                    Assembly.Extension.ShowSmartMessage NoUp & " Parts not updated due to lightweight (" & Timer - tm & "s)", 10000, True, True
