I've been working on a macro that will select the front face of a part and save it as a DXF file. We currently have to do this one file at a time so we can send the files to our manufacturing department. I'm pretty new at API so I've been piecing together parts from other examples I have found in the forum.
When I run the macro, it doesn't seem to be saving the file as I requested. ANy Idea what's going on?
Here is the code
Option Explicit
'Get the front face variables
Dim swDoc As SldWorks.ModelDoc2
Dim swPartDoc As SldWorks.PartDoc
Dim swBody As SldWorks.Body2
Dim swBodyVar As Variant
Dim swFaceVar As Variant
Dim bodyCount As Long
Dim MyPlane As Object
Dim myFace As SldWorks.Face2
Dim faceCount As Integer
Dim edgeCount As Integer
Dim dDist As Double
Dim vP1 As Variant
Dim vP2 As Variant
Dim vEdges As Variant
Dim bCoin As Boolean
Dim boolstatus As Boolean
Dim myEdge As SldWorks.Edge
'Save As DXF Variables
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
Dim FileName As String
Dim NameSize As Long
Dim NewFileName As String
Dim NameNoExtension As String
'Get Face Code
Set swDoc = swApp.ActiveDoc
Set swPartDoc = swDoc
Set swSelMgr = swDoc.SelectionManager
swDoc.ClearSelection2 True
boolstatus = swPartDoc.Extension.SelectByID2("FRONT", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
If swSelMgr.GetSelectedObjectCount2(-1) <> 1 Then
Exit Sub
Set MyPlane = swSelMgr.GetSelectedObject6(1, -1)
swBodyVar = swPartDoc.GetBodies2(swSolidBody, False)
bodyCount = 0
For bodyCount = 0 To UBound(swBodyVar)
Set swBody = swBodyVar(bodyCount)
swFaceVar = swBody.GetFaces
For faceCount = 0 To UBound(swFaceVar)
Set myFace = swFaceVar(faceCount)
bCoin = True
vEdges = myFace.GetEdges
For edgeCount = 0 To UBound(vEdges)
Set myEdge = vEdges(edgeCount)
dDist = swDoc.ClosestDistance(MyPlane, myEdge, vP1, vP2)
If dDist > 0 Then
bCoin = False
Exit For
Next edgeCount
If bCoin Then
myFace.Select True
Next faceCount
Next bodyCount
'Save DXF Code
FilePath = swDoc.GetPathName
PathSize = Strings.Len(FilePath)
FileName = swDoc.GetTitle
NameSize = Strings.Len(FileName)
PathNoExtension = Strings.Left(FilePath, PathSize - 17)
NameNoExtension = Strings.Left(FileName, NameSize - 6)
NewFileName = NameNoExtension & ".dxf"
NewFilePath = PathNoExtension & "Waterjet Files\"
swDoc.SaveAs (NewFilePath & NewFileName)
