4 Replies Latest reply on Jan 1, 2015 3:21 AM by Yong Ning
    How to set the name of the general table other than 'General Table1'?
    Arie Van Gelderen
      Hi all,
      I wrote a macro to insert a general table into a drawing. To insert the table I use the InsertTableAnnotation2 method. The macro works fine but I can't control the name of the table. My question is: is there a way to set the name of the general table other than 'General Table1' or 'General Table2' and so on?
      Hope someone can help me out here.
      Kind regards,
      Arie
        • Re: How to set the name of the general table other than 'General Table1'?
          Matt Martens
          Try this. When you insert the table it comes in as a ITableAnnotation object so convert it to an IAnnotation object using ITableAnnotation::GetAnnotation and use IAnnotation::SetName to change the name of it.
              Arie Van Gelderen
              Hi Matt,
              Your solution was not what I was looking for. Your method sets/gets the annotation name and not the feature name. Debug.Print (tableName) returns 'DetailItem5349' instead of 'General Table1'.
              I found a solution myself though:
              Dim swApp               As SldWorks.SldWorks
              Dim swModelDoc          As SldWorks.ModelDoc2
              Dim swTable             As SldWorks.TableAnnotation
              Dim swGenTabFeature     As SldWorks.GeneralTableFeature
              Dim swFeature           As SldWorks.Feature
                  Set swModelDoc = swApp.ActiveDoc
                  Set swTable = swModelDoc.InsertTableAnnotation2(True, 0, 0, swBOMConfigurationAnchor_BottomRight, <PATHNAME>, 2, 4)
                  Set swGenTabFeature = swTable.GeneralTableFeature
                  Set swFeature = swGenTabFeature.GetFeature
                  Debug.Print (swFeature.Name)
                  swFeature.Name = "Tablename"
              Thanks for the help anyway.
                  Yong Ning
                  Private Sub ll()
                    Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc, SwModel As ModelDoc2
                    Set SwApp = Application.SldWorks
                    Set SwDraw = SwApp.ActiveDoc
                    Dim GenTabFeat As GeneralTableFeature
                    Dim SwFeat As Feature, SwSubFeat As Feature, Ss
                    Dim SwGenTabFeat As GeneralTableFeature, SwGenTab As TableAnnotation
                    Dim SwSelMgr As SelectionMgr
                    With SwDraw 'SwModel
                       Set SwSelMgr = .SelectionManager
                       Set SwFeat = .FirstFeature
                       Do While Not SwFeat Is Nothing
                          'Debug.Print SwFeat.Name, SwFeat.GetTypeName
                          Set SwSubFeat = SwFeat.GetFirstSubFeature
                          Do While Not SwSubFeat Is Nothing
                             If SwSubFeat.GetTypeName = "GeneralTableFeature" Then
                                Debug.Print "   ******" & SwSubFeat.Name, SwSubFeat.GetTypeName
                                SwSubFeat.Select True
                                Set SwGenTabFeat = SwSelMgr.GetSelectedObject6(1, 0)
                                Ss = SwGenTabFeat.GetTableAnnotations
                                Set SwGenTab = Ss(0)
                                Debug.Print SwGenTab.RowCount, SwGenTab.ColumnCount
                                Debug.Print
                                Debug.Print
                             Set SwSubFeat = SwSubFeat.GetNextSubFeature
                          Loop
                          Set SwFeat = SwFeat.GetNextFeature
                       Loop
                    End With
                  Private Sub del20150101_1()
                     Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                        Set SwModel = SwApp.ActiveDoc
                        SwModel.ClearSelection
                     Dim SwDraw As DrawingDoc, SwView As View, Ss
                        Set SwDraw = SwModel
                        Set SwSelMgr = SwDraw.SelectionManager
                     Dim SwAnn As TableAnnotation, SwGenFeat As GeneralTableFeature, SwFeat As Feature
                        Set SwFeat = SwModel.FeatureByName("Dn表")
                        Set SwGenFeat = SwFeat.GetSpecificFeature2
                        SwFeat.Select True
                        Set SwGenFeat = SwSelMgr.GetSelectedObject6(1, 0)
                        Ss = SwGenFeat.GetTableAnnotations
                        Debug.Print SwGenFeat.GetFeature.Name
                        Set SwAnn = Ss(0)
                        With SwAnn
                           '.InsertColumn 2, 0, "aa"
                           .DeleteColumn 1
                           .DeleteRow 0
                        End With
                        'Stop
