11 Replies Latest reply on Nov 23, 2016 2:22 AM by Alexandre Gragnano
    Macro Feature, SetSelections2 won't update the MacroFeatureData object
    Jacob Corder
      Hi. I'm having issues with replacing a selected face in my macro feature. I have a face that is selected and defines a features selected face similar to editing a 2d sketch's plane.
      My code calls macrofeature.accessselections
      Getselectedobjects
      Replace the current face's selected object index with with the new face.
      Setselectedobjects2
      Macrofeature.modifydefinition
      But it just doesnt work. I keeps the old selected face.
      I can set selections to nothing and that updates but replacing that selectedobjects index fails.
      Ill attach the code in the morning.
        • Re: Macro Feature, SetSelections2 won't update the MacroFeatureData object
          Jacob Corder
          Ok. I was able to figure it out. The only reason why it wasnt working is that if i call MacrofeatureData.SetSelections2(SelObj,SelMarks,SelDrViews) it fails. But if I Call MacroFeatureData.SetSelections(SelObj,SelMarks) it works. so for some reason SetSelections2 does not work but SetSelections() does work.
          so im just going to use the obsoleted api SetSelections()
              Mohammed Elkalakhi
              Hell Jacob,
              I have the same problem, but even MacroFeatureData.SetSelections(SelObj,SelMarks) doesn't work for me,
              Could you pass me a sample of your code to see how you resolve it.
              Thank you in advance.
                  Jacob Corder
                  Basically all i am doing is looking for the current item, and replaceing it with  a new item. The thing that bothers me the most is that the objects must be an array of a specific type like Face2() or body2() i have tried using objects() but it also failed. so luckily i was only needing to use faces.
                           Dim SelDrawingViews As Object = Nothing
                                                          Dim SelMarks As Object = Nothing
                                                          Dim SelObj As Object = Nothing
                                                          Dim SelTypes As Object = Nothing
                                                          Dim SelReplaced As Boolean = False
                                                          ParFeatData.GetSelections3(SelObj, SelTypes, SelMarks, SelDrawingViews, Nothing)
                                                          If IsNothing(SelObj) = False And IsNothing(SelTypes) = False Then
                                                              For i = LBound(SelTypes) To UBound(SelTypes)
        Select Case CType(SelTypes(i), swSelectType_e)
        Case swSelectType_e.swSelFACES
        If CurrentFeatureFace.IsSame(SelObj(i)) = True Then
        SelObj(i) = NewFeatureFace
        SelReplaced = True
        End Select
                                                              Next
                                                              If SelReplaced = True Then
        Dim SelFaceObj() As Face2 = Nothing
        Dim SelMarkInt() As Integer = Nothing
        For i = LBound(SelObj) To UBound(SelObj)
        If SelTypes(i) = swSelectType_e.swSelFACES Then
                  'This just calls a function that adds a face to an array of faces.
        JEMArrays.AddFaceToFaceArray(SelFaceObj, TryCast(SelObj(i), Face2), True)
        JEMArrays.AddIntegerToIntegerArray(SelMarkInt, CInt(SelMarks(i)), True)
        Next
                  'HERE IS THE ONLY WAY IT WORKS for me.
                  SelFaceobj is an array of faces
        ParFeatData.SetSelections(SelFaceObj, SelMarkInt)
                Mohammed Elkalakhi
                This is my code :
                Public Sub EditMacroFeature()
                        Dim newSel As Object
                        Dim mark As Integer
                        Dim selObj, selTypes, selMarks As Object
                        Dim newSelObj() As DispatchWrapper
                        Dim newSelMarks() As Integer
                        Dim drViews() As View
                        Try
                            swFeatData.GetSelections3(selObj, selTypes, selMarks, Nothing, Nothing)
                            If newSel Is selObj(0) Then Exit Sub
                            selObj(0) = newSel
                            selMarks(0) = mark
                            ReDim Preserve newSelObj(0)
                            ReDim Preserve newSelMarks(0)
                            ReDim Preserve drViews(0)
                            newSelObj(0) = New DispatchWrapper(selObj(0))
                            newSelMarks(0) = selMarks(0)
                            drViews(0) = Nothing
                            swFeatData.SetSelections2(newSelObj, newSelMarks, drViews)
                            ' I also tried this swFeatData.SetSelections(newSelObj, newSelMarks)
                            swFeature.ModifyDefinition(swFeatData, swDoc, swComponent)
                        Catch ex As Exception
                            Throw ex
                        End Try
                I dont see why this does not work ?
                Please help me!
                    Jacob Corder
                    I dont think its working because your not chaning the selected objects. Your just passing the same parameters back. Try to send it a new selection. I think solidworks checks to see if the current objects are the same.
                      Jacob Corder
                      I was able to use the DispatchWrapper successfully this morning. however, it does not work with SetSelections2. It only works with SetSelections(). Thanks to Artem, i can now have many different selection types.
                      'If The Feature Face has changed then process it as follows.
                                                      If IsNothing(NewFeatureFace) = False Then
                                                          If ParFeatData.AccessSelections(ModDoc, Nothing) = True Then
                                                              ModDoc.ClearSelection2(True)
        SelReplaced = True
        End Select
        Next
        Dim SelFaceObj(UBound(SelObj)) As DispatchWrapper
        SelFaceObj(i) = New DispatchWrapper(SelObj(i))
        Next
        ParFeatData.SetSelections(SelFaceObj, SelMarks)
                      Mohammed Elkalakhi
                      Now its work for me
                      I only need to add this line code :
                      swFeatData.AccessSelections(swDoc, swComponent)
                      before calling GetSelections3 method.
                      Thank you for your help
                        Alexandre Gragnano
                        Be careful to pass typed array to the method SetSelections2:
                        Take a look at Re: MacroFeature & PMPSelectionbox
