I'm working in Solidworks Simulation 2013. I've set up a number of simulation data sensors to monitor max stresses and displacements across an assembly. The sensors behave fine when the study is first run, but if I close and reopen the file, the sensors no longer retain the same data ("data not available"). Updating the sensors does not change anything. The result files are all located in the same folder, and the overall results still display, only the sensor data is lost. Is there a way to reactivate the sensors without having to run the study again?
Also, is it possible to export simulation data sensors into a .csv?
Export sensors as csv, only from a design study I believe and only as copy paste.
Sensor losing info, happens on all files? Even a simple block fixed on one side and force on the other? All types of sensors? What sp of 2013?
