I have an assembly that uses holes series, everything was fine untill today I opened the assembly make some changes. After I made a few changes (added a part and subassembly, corrected a few mates). I notices that the holes on wither side of each other were offset. Has anyone ever encountered this and better yet found a solution?
The holes with red arrows are the ones offset from one another, I have the same parttern on the other side that is allso offset. The ones circled in blue seem to be fine.
Try a Ctrl-Q rebuild....
Make sure the holes in your parts have the incontext relationships that you think they have. No question marks in any of your sketchs.
Are you using Mirrors? May be an issue there depending on how you have those setup.
Cheers,
Anna
