1 Reply Latest reply on Nov 24, 2016 1:12 PM by Justin Logan
    Activate Layer and Print to PDF
    Peng Cha
      Below is my original post in EPDM forum.  I was advised to post in this forum.  Can anyone help?
      Hello all,
      Our vault has 4 main folders, engineering, production, quality, and sales. Within each main folder, the sub-folder structure is the same/very similiar. The idea is to create a task that would output a PDF using a SolidWorks drawing found in the engineering folder and place it in the same named folder in the quality folder. There are multiple folders with the same name due to sub-folder structure.  I am trying to output a PDF during a transition that would carry over metadata, save the PDF to the correspoding sub-folder structure, and activate a certain layer (always has the same name).  I believe this can be done using Advanced Scripting Options under Tasks (Output to PDF). I do not know much about VBA scripting other than cutting and pasting.  Any help would be appreciated.
