Use API to Check Part/Assembly Fully Defined?
Question asked by Andre Colemen on Feb 4, 2014
Latest reply on Aug 14, 2018 by Josh Brady
I've been searching on and off for an answer or method to this question for a while.
Is it possible to use the API to check or get the constraint status of a part or assembly? (Fully Defined, Under Defined, etc.)  So far, I have found a solution that is specific to Sketches, but what I am looking for is a 'Get' command or some type of check that I can run to return an output for a specified Assembly that just tells me the constraint status of the assembly.  My initial guess was that there would be a command specific for this, since the Feature Manager tree has the '(-) symbols next to any part in the assembly that is under-defined. But this has proven to be much more obscure to figure out.
Thanks for any help.
