Hello, how do I go about configuring a custom part that was manually added to the toolbox? I created some simple tubing peices but cannot adjust the lengths of after inserting them into an assembly through the "configure component" option. Is there a way to accomplish this using this option or will I have to take a different approach?
Stephen,
Welcome to the forum
If you are using SW prior to 2012, you could do this by modifying the database file.
The other option is to use the design library feature.
