how can one link your property tab builder in solidworks to PDM bom
Owen,
The only way to do this is to add the same information to a BOM in the administration tool. You should probably choose this option on each variable:
I have tried that,but did not work
1) What didn't work exactly?
2) Did it have blank fields in the BOM?
3) Are the fields on the datacard?
4) Are the values in the custom properties but not the configuration specific properties?
5) Are all the custom properties mapped to variables?
1.It does not show in PDM bom which shows a blank field
2.Also does not show on the datacard
3.Yes the values are in custom properties but not in the configuration specified properties
4. I have mapped all properties to variables
Have you mapped the variable to your solidwork file types?
Hmm, is the custom property name different than the variable name? I think I remember hearing that it searches for a custom property with the same name as the variable as opposed to the attribute mapping but I can't find that anywhere now...
Owen,
