Greetings all,
I'm trying to render a model so that the material looks the same as the one in attached pictures, I am not getting good results. I am not very good with Photoview - all I have tried so far is the default materials in Solidworks that are reflective or have texture such as chrome, knurled steel, cast chrome etc (I have played about with mapping and reflectivity to no avail). I have also tried some of the appearances/materials from the Luxology site but haven't had much luck with that either.
I have no tried adding lights or cameras yet. Any thoughts, hints and suggestions would be great. Model is attached.
Cheers,
Dave
Hi Dave,
I've updated the SW texture for you. Try using Soft Box environment in your render and adjust your brightness and reflection amount to your liking. Play around with different environments until you find the one that suites your model.
Brian
