How do you get the Select Chain option to work in Offset Entities? It seems useless to me.
That works, but I am first selecting Offset Entities - Select Chain, then selecting an edge expecting to get all the edges in a chain. It doesn't happen.
What version are you using?
I just tried both ways to double-check (SW2013). I sketched a rectangle, activated the "Offset Entities" function, "Select Chain" was activated. I selected one edge and the entire rectangle was offset.
Cleared out the command and re-activated it, de-selected "Select Chain", clicked one edge and only got one edge offset, went back to the PropertyManager, selected "Select Chain", and the other three sides were offset.
So for me it works fine, regardless of which order the selections are made.
What happens when you try?
I simply right click a sketch entity, select Select Chain (and the connected entities show as being selected), then activate the Offset tool, set the distance & direction, and hit the green check mark. Done.
