0 Replies Latest reply on Feb 3, 2014 9:33 AM by Vincent Danilov
    Is it possible to have a "preview" on customized "section view method"
    Vincent Danilov
      Hi to everybody,
      the screenshot shows the cut view property manager and the preview upon calling the section view in solidworks.
      I would like to implement a customized section view method which would allow to select a cylinder (then take the center of the cylinder and create an appropriate reference plane there  ... the details of this are actually of no concern here - my question is a more general one).
      I recored with the macro recorder what was going on beneath the standard "section view" in solidworks - obviously the macro recorder can only eavesdrop on API calls after the OK-button  (the green tick) has been clicked:
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set Part = swApp.ActiveDoc
      Dim myModelView As Object
      Set myModelView = Part.ActiveView
      myModelView.FrameState = swWindowState_e.swWindowMaximized
      boolstatus = Part.Extension.SelectByID2("Vorne", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
      Dim sViewData As Object
      Set sViewData = Part.ModelViewManager.CreateSectionViewData()
      Set sViewData.FirstPlane = Nothing
      sViewData.FirstReverseDirection = False
      sViewData.FirstOffset = -0.0975
      sViewData.FirstRotationX = 0.1221730476396
      sViewData.FirstRotationY = 0.08726646259972
      sViewData.FirstColor = 16711680
      sViewData.ShowSectionCap = True
      sViewData.KeepCapColor = False
      sViewData.GraphicsOnlySection = False
      boolstatus = Part.ModelViewManager.CreateSectionView(sViewData)
      Part.ClearSelection2 True
      If one calls the section view does some adjustments in the property manager and then cancels the property manager - then the macro recorder does not record much:
      Dim swApp As Object
      Dim Part As Object
      Set swApp = _
      My question: Is it all somehow possible to have previews on customized methods in solidworks ?
