I am in the process of carry out some more CFD analysis on an intake manifold and I can get all the usual pressure & velocity results but I am unable to produce mass/volume flow results.
Can anyone chime in and provide me with some tips on what boundary conditions, and anything else that is required, to produce mass/volume flow results
Ariel
What is your setup?
Your options in flow are pressure inlet, pressure outlet to get flow rate through the system. Or velocity/mass flow/volume flow and pressure to determine the pressure at the flow end.
In either situation the mass or volume flow are measured on the lids with surface goals or parameters.
