10 Replies Latest reply on Feb 10, 2014 8:52 AM by Simon Turner
    Exporting Excel Data into MS Access
    Parminder Singh
      Apoologies Guys, Posting help other than Solidworks.
      Need little help to Export Data from MS Excel To MS Access Database.
      I've succesfully able to Export the data into the database.
      Only stuffup with the Duplicate Entry.
      Assume i've data which is already into Access Table and still if im exporting it,
      the code should give the count of duplicate entry found and paste the other non duplicate entries.
      Please find the Macro enable Excel Sheet and MS Access Database.
      Really glad if someone assist me on this.
        • Re: Exporting Excel Data into MS Access
          Simon Turner
          Sub ADOFromExcelToAccessdbo_PartInformation()
          ' exports data from the active worksheet to a table in an Access database
          ' this procedure must be edited before use
          Dim cn As ADODB.Connection, rs As ADODB.Recordset, rs2 As ADODB.Recordset, r As Long
          Dim myBook As Workbook
          Dim fso As New Scripting.FileSystemObject
          Set myBook = Application.ActiveWorkbook
          With ActiveSheet
              ' connect to the Access database
              Set cn = New ADODB.Connection
              cn.Open "Provider=Microsoft.ACE.OLEDB.12.0; " & _
                  "Data Source=" & fso.GetParentFolderName(myBook.FullName) & "\SQL.accdb;"
               'open a recordset
              Set rs = New ADODB.Recordset
              Set rs2 = New ADODB.Recordset
                      rs.Open "dbo_PartInformation", cn, adOpenKeyset, adLockOptimistic, adCmdTable
                      ' all records in a table
                      r = 2 ' the start row in the worksheet
                      Do While Len(Range("A" & r).Formula) > 0
                          XX = Range("A" & r).Value
                          YY = Range("B" & r).Value
                          ZZ = Range("C" & r).Value
                          KK = Range("D" & r).Value
                          'If DCount("*","[NameOfYourTableToCheck]", "[IDField] = " & SomeID & " AND [OtherField] = " & SomeOtherFiled) > 0 Then
                          'If DCount("*", "[dbo_PartInformation]", "[ParentProductNbr] = " & XX & " AND [SubEM] = " & YY) > 0 Then
                          rs2.Open "SELECT COUNT(*) AS Tot FROM dbo_PartInformation WHERE ParentProductNbr='" & XX & "' AND SubEM='" & YY & "'", cn
                          If rs2("Tot") > 0 Then
                              MsgBox "This record already exists", vbOKOnly + vbExclamation, "Duplicate Record"
                              rs2.Close
                          Else
                              rs2.Close
                              ' repeat until first empty cell in column A
                              With rs
                                  .AddNew ' create a new record
                                  ' add values to each field in the record
                                  .Fields("ParentProductNbr") = XX
                                  .Fields("SubEM") = YY
                                  .Fields("ProductNbr") = ZZ
                                  .Fields("SubAssemblyInfo") = KK
                                 .Update ' stores the new record
                              End With
                          r = r + 1 ' next row
                      Loop
                      rs.Close
                      cn.Close
              'MsgBox "Database updated", vbOKOnly
              lastRow = (.Cells(.Rows.Count, "A").End(xlUp).Row - 1)
              MsgBox "You are about to Paste" & " " & lastRow & " " & "Record(s).", vbExclamation
             End With
