17 Replies Latest reply on Feb 6, 2014 10:18 AM by Chris Johnson
    Open Part Model associated with Titleblock
    Chris Johnson
      Hi All,
      I have a question for you.
      How would I go about determining which drawing view is associated with the title block and then open that part/assy?
      basically, I've written a macro that made some changes to a drawing and now i want to open the part/assy model and make some changes to that also, but I don't know how.
      I recorded a macro to try and figure it out but, I'm thinking there must be a cleaner way to get this done.
      it is important that the macro doesn't care if its a part or assy model because this macro will be used for both.
      thanks in advance for your help!
      Chris
        • Re: Open Part Model associated with Titleblock
          Deepak Gupta
          Do you have different part/assy views in the same drawing?? If not then you can use the first view in the drawing to get/open the referenced model.
          Check for Get Document Referenced by Drawing View (VBA) example in SW API help files.
            Matt Martens
            Dim swSheet as SldWorks.Sheet
            Dim swView as SldWorks.View
            Set swSheet = swModel.GetCurrentSheet
            Set swView = swModel.GetFirstView
            If swSheet.CustomPropertyView = "Default" Then
                Set swView = swView.GetNextView
            Else
                Do While Not swView.Name = swSheet.CustomPropertyView
                Loop
            Dim swModel as SldWorks.ModelDoc2
            Set swModel = swView.ReferencedDocument
            The above code will look at the sheet properties and determine which drawing view is associated with the title block properties and then return the model doc object for the model in that view.
                Chris Johnson
                Matt,
                This helps alot!
                once I figure out how to open the model after I get the firstview I should be good to go.
                Chris
                    Matt Martens
                    Once you get the ModelDoc2 object retrieve the document filename using IModelDoc2::GetPathName and the type using IModelDoc2::GetType and pass them to one of the ISldWorks::OpenDoc methods.
                        Chris Johnson
                        Got it, thanks for the help!!
                        Chris
                            Chris Johnson
                            Matt,
                            with your help from yesterday, I have cobbled together some code that is supposed to print the name of the model in the drawing view  and then open that model.
                            it prints just fine but it wont open the model.
                            Would you be kind enough to have a look and let me know if you see any problem?
                            thank you,
                            Chris
                                Option Explicit
                                Dim swApp                     As SldWorks.SldWorks
                                Dim swModel                   As SldWorks.ModelDoc2
                                Dim swModView                 As SldWorks.ModelView
                                Dim swView                    As SldWorks.View
                                Dim swDraw                    As SldWorks.DrawingDoc
                                Dim nDocType                  As Long
                                Dim nErrors                   As Long
                                Dim nWarnings                 As Long
                                Dim sModelName                As String
                                Dim swSheet                   As SldWorks.Sheet
                                Dim sDocFileName              As String
                                'Connect to Solidworks & active document
                                    Set swModel = swApp.ActiveDoc
                                    Else
                                        Loop
                                sDocFileName = swModel.GetPathName
                                    Debug.Print sDocFileName
                               'Determine type of SolidWorks file based on file extension
                                    If InStr(LCase(sDocFileName), "sldprt") > 0 Then
                                        nDocType = swDocPART
                                    ElseIf InStr(LCase(sDocFileName), "sldasm") > 0 Then
                                        nDocType = swDocASSEMBLY
                                    ElseIf InStr(LCase(sDocFileName), "slddrw") > 0 Then
                                        nDocType = swDocDRAWING
                                    Else
                                    ' Probably not a SolidWorks file...
                                    nDocType = swDocNONE
                                    '...so the file cannot be opened
                                    Exit Sub
                                Set swModel = swApp.OpenDoc6(sDocFileName, nDocType, swOpenDocOptions_Silent, "", nErrors, nWarnings)
